Good deal on the traction bar. I think you'll notice a difference, especially on climbs.
Smog pump...whats a smog pump?? Confusedcratchhe:
Haven't had one on my rig for 20 years. It might gian you a few HP's as well.
Nick
nhopman Wrote:Good deal on the traction bar. I think you'll notice a difference, especially on climbs.
Nick
:hysterical:...yeah, well this ole 5.0 came with a busted smog pump...so I found the belt size and look pretty easy to eliminate. one other thing i forgot to mention...I got a nice large tranny cooler Im gonna use for the power steering. the small elec fan I had as a 2nd cooling fan for the radiator will fit the cooler perfect for mounting the cooler under the driver side floor.
after looking at the traction bar, looks like the in board shocks are gonna get moved!!:banghead: I will place them on the back side of the axle tube so I can use the front side for the traction bar. pouring down right now, and as any of you have been in my garage when it pours....ITS LOUD!(steel roofs suck at times)
quit crying and fix that junk!!!
blazinchuck Wrote:... pouring down right now, and blah, blah, blah, blah, my vagina hurts :crying:
Fixed it for ya Chuck :xyxthumbs:
X2 Chuzie
josephitguy Wrote:Fixed it for ya Chuck :xyxthumbs:
X2 Chuzie
you like swinging from chuzie eh?:thefinger:
you just jealous I have it the option to use a garage, but choose not toConfusedmokin:
got my new bump stop mounts fabbed up and welded in...they work great! ill post pic later. got the steering cooler mounts tacked in, still need to weld them. i tried relocting the shocks to the backside of the axlle housing, but it looks like it will work better if they mount on top of the axle...but for that to happen...i need shorter shocks.
heres a few pics
got the steering cooler mounted and welding in. Im relocating the driver side rear shock to the backside of axle housing, i'll leave the pass side like it was.
I removed the smog pump and went and bought the belt that was recommended from classic...however Im running the premier welder and alt with a small pulley...so the 84.5"belt didnt work for me. tomorrow I'll swap it for a 75.5 belt.
nice!!!
Lookingood!
  Bertolini's '71 build blazinchuck 4 2,075 09-13-2015, 08:49 PM
