306 EFI build
#31
also, when i 1st did my efi swap...i had to lose my schrader valve. so a while back...i found a tbird with the fuel connectors and pressure valve on the pass side like what i have.
any problems if i go with this for this 306? is it better or worst than the mustang HO fuel rail?
injectors:
the guy that i got the gt40 intake from gave me 2 sets of 19lb injectors. doesnt look like any of them have been rebuilt, but there was a bcbroncos with what looks like the upper/lower o-rings for injectors(can anyone confirm this)
should i do anything with these injectors? pop test? rebuild? or use what im using right now with the 5.0?
and in one of the pics...you can see a small crack in the line. this is the front cross-over fuel rail line. it looks like a grey protective jacket...yall think this is ok? i dont see any damage under it at all. thanks again guys
yeah, a 97 would have had the non-P heads. Balancer would be the 3 bolt type. I have robbed one off of a 97 before.
Not sure if you've gone to the 90 degree thermostat housing yet. You'll need it.
You did a good job cleaning that engine up. Keep it up and I'll send a few your way Big Grin
ayone got thoughts on the intake hitting the valve cover?? i dont want to buy a spacer.
i want to cut or remove that pressed in 90 and maybe thread it for a plug??? never tried to pull one of these out
heck, i think it wouldn't be hard at all to remove the fitting and tap it. I'd use a pipe thread on it. While you are at it, I'd tap the lower intake (for the EGR port) and plug it off, like I did on my build thread.
broncosbybart Wrote:heck, i think it wouldn't be hard at all to remove the fitting and tap it. I'd use a pipe thread on it. While you are at it, I'd tap the lower intake (for the EGR port) and plug it off, like I did on my build thread.
can you show me what youre talking bout? thx
Yes, those are the injector o-rings. I would soak the injectors in some sea foam for a night and then do a pop test on them.
If you need to upgrade I have several sets of 24 lbs injectors I can swap for something.
The fuel rails look like they should work. I don't think you need to up grade them to billet logs...yet:bdent:
The Trick Flow set up works very well with fuel injection. Their stuff even allows for further mods down the road if needed. If I remember correctly, the engine Carl W. ran in his Bronco had a TFS head/cam combo...
[YOUTUBE]0SDUFp7kqK4&list[/YOUTUBE]
Can't get the flippin' link to embedSad
i edited it Aaron...its kinda a pain
I believe that stuff is cast aluminum so keep in mind if you screw it up you will be going to the junk yard for a replacement
broncosbybart Wrote:yeah, a 97 would have had the non-P heads. Balancer would be the 3 bolt type. I have robbed one off of a 97 before.
The years of the non-P head was 96-97.5 so some of the 97 will have the dreaded P heads.
blazinchuck Wrote:also, when i 1st did my efi swap...i had to lose my schrader valve. so a while back...i found a tbird with the fuel connectors and pressure valve on the pass side like what i have.
[COLOR="Red"]Should be no difference in fuel rails until you start dealing with the Cobra stuff. The fuel press reg will be different.
[/COLOR]
injectors:
o-rings should be cheap from the parts house... i think.
go with what you have for now. 19lb is stock for these motors. I would test/ clean for spares though. plenty of good write-ups for that.
and in one of the pics...you can see a small crack in the line. this is the front cross-over fuel rail line. it looks like a grey protective jacket...yall think this is ok? i dont see any damage under it at all. thanks again guys Do a pressure test with the air on it and see if it leaks. if so, you can cut it off and replace it with high pressure efi hose and efi clamps.
  Berg Build - New Guy here tcb3078 27 7,370 11-13-2018, 06:45 AM
Last Post: NicholasMo
  Tweaking Chucks most excellent build NC-Fordguy 11 3,752 02-26-2017, 01:54 PM
  Well it is time to build one from scratch... shon 4 2,764 05-25-2015, 04:28 PM
  Build threads rtj731 4 2,039 06-11-2014, 11:28 PM
  Mini build up / fix'em up jollygrngiant 30 7,094 06-04-2013, 12:22 PM
  Bronco build questions AReed 12 3,442 03-23-2011, 04:12 PM
Last Post: AReed
  efi berg bronco 5 1,446 09-07-2010, 08:01 AM
  Fall build abunchofidiots 5 2,263 10-01-2009, 10:29 AM
Last Post: abunchofidiots
  5.0 EFI/435 blazinchuck 13 2,858 09-26-2009, 06:11 PM
  Build sheets cdeal28078 17 4,786 11-08-2007, 01:22 PM
Last Post: Roughshod
