306 EFI build
#61
well, that sucked!! FML...just pulled everything off the front of the block. i really had no idea if the cam shaft bolt was clearing the explorer cover...now i know!
and in the process of removing the timing cover, i just so happened to completely destroy the brand new 1 piece oil pan gasketanother $30 down the drain.
guess i need to grind the bolt now and buy all new gaskets
better to find it and fix it now than after it's all installed.
Nick
i agree...but it is a set back. i wasnt planning to buy another $60 worth of gaskets. i was hoping to get the ford racing plug wires...dont know now
What led you to remove it to find the problem?
SC74 Wrote:What led you to remove it to find the problem?
his conscious
Read a few tech articles that mentioned it, I didn't notice anything when I installed cover. So I needed to be sure
hmmmm... did you have this problem chuzie? I have not heard of this before but now has me curious too.
I have heard of the cam bolts hitting but never knew anybody who actuly had it happen. Glad you caught it right away.
You can move the plug wires down so that the dist fits, You can also make a custom harness to move the modual off the dist but its a bunch of work that often falls apart. My preferance was to move all the wires over once so I could clock the dist.
Sucks about the gaskets, too bad you couldent save them.
well, i found out it's not that easy Matt...the TFI and computer are timed to the #1 on the cap. which means, if i move the wires one-over...my fuel injectors will be firing at the wrong time. Im gonna trim the AC/PW steering bracket some..I think that will be all that needs to be done. wont really know til I drop the distr. in and fire it up.
i was hoping to drop the motor in this weekend coming. Dont think that is gonna happen right now. I need to replace at the gaskets. I would like th\o install new timing set, and order the plug wires. of coarse I was checking out the free distr and it looks really nasty...lots of dirt and debris inside it. full loaded distr is $100...UGH!
mo MONEY
Next trip to the junk yard you might be able to find the stuff to make a remote TFI mount. I thought about doing this mod when/if I put the Explorer front dress on mine.
http://www.therangerstation.com/tech_lib...te_tfi.htm
Nick
  Berg Build - New Guy here tcb3078 27 7,453 11-13-2018, 06:45 AM
Last Post: NicholasMo
  Tweaking Chucks most excellent build NC-Fordguy 11 3,792 02-26-2017, 01:54 PM
  Well it is time to build one from scratch... shon 4 2,772 05-25-2015, 04:28 PM
  Build threads rtj731 4 2,057 06-11-2014, 11:28 PM
  Mini build up / fix'em up jollygrngiant 30 7,174 06-04-2013, 12:22 PM
  Bronco build questions AReed 12 3,471 03-23-2011, 04:12 PM
Last Post: AReed
  efi berg bronco 5 1,493 09-07-2010, 08:01 AM
  Fall build abunchofidiots 5 2,281 10-01-2009, 10:29 AM
Last Post: abunchofidiots
  5.0 EFI/435 blazinchuck 13 2,934 09-26-2009, 06:11 PM
  Build sheets cdeal28078 17 4,833 11-08-2007, 01:22 PM
Last Post: Roughshod
