306 EFI build
I work for half price. Guess I'm the government's slut.
You are one of those cheap Ho's, and I'm more of a High dollar escort.:toothy12:
talk about some hijacking fools!
Chuzie is a cheap Ho.:thefinger:
sorry. I'm done....Confusedupergrin:
So what you are saying is, is that you'll both do the same things, you just need more money to do it???
IF that correlates into your Bronco hobby, DON'T follow the example of the EFI guy in the yellow EB that has about 2-3 million wires in it. Just because you'd spend more for the wires doesn't make it better. :hysterical:
That is all. Carry on.
Though I guess that if there is a plus side to that, it'd be that you could afford gas money.
(Someone insert a pic here of Chuzie out of gas on one of the multiple occassions).
broncosbybart Wrote:So what you are saying is, is that you'll both do the same things, you just need more money to do it???
spend more money on wiring and less money on fuel..dont need fuel anyways...not that it wont leave ya stranded between a rock and hard place.
Just to set the record straight, not have I have to...
I have just as many wires as anyone else albeit they are not nearly as pretty.
I have NEVER run out of gas on the trail although I have been in a position to allow the pickup to run dry. Running out of gas and not being able to utilize your gas are two different issues.
That electrical issue on the trail had nothing to do with my cheap wiring but rather my inferior crimping technique.
So, **** your couches, **** your couches, and **** your ****ing couches!
Bunch of jealous *****es.
  Berg Build - New Guy here tcb3078 27 6,276 11-13-2018, 06:45 AM
Last Post: NicholasMo
  Tweaking Chucks most excellent build NC-Fordguy 11 3,273 02-26-2017, 01:54 PM
  Well it is time to build one from scratch... shon 4 2,517 05-25-2015, 04:28 PM
  Build threads rtj731 4 1,795 06-11-2014, 11:28 PM
  Mini build up / fix'em up jollygrngiant 30 6,058 06-04-2013, 12:22 PM
  Bronco build questions AReed 12 2,912 03-23-2011, 04:12 PM
Last Post: AReed
  Fall build abunchofidiots 5 2,012 10-01-2009, 10:29 AM
Last Post: abunchofidiots
  5.0 EFI/435 blazinchuck 13 2,342 09-26-2009, 06:11 PM
  Build sheets cdeal28078 17 4,100 11-08-2007, 01:22 PM
Last Post: Roughshod
