  • 2 Vote(s) - 5 Average
Please post some more pics of the ram setup and the front steering components.
Thx.
I will... it was too dark to get good pics and the flash just made them worse. I'll get some more in good light.
firefighter2134 Wrote:i have a set of wh 4 1/2 inch coils if you may be interested in trading
Hmmmm... what brand? Progressive or linear spring?
I say I have 3.5" but they may be 4.5"??? Confusedcratchhe: I have CAGE springs and can count the number of coils to compare if yours are CAGE also.
Thanks for the offer.
meh, cut the front fenders some more Big Grin
They are rock crawler coils from wild horses
broncosbybart Wrote:meh, cut the front fenders some more Big Grin
That's not the problem... I would trust me!
I don't have enough up travel. My long arms will bottom out on the bottom of the frame with about 3 or 3.5" of up travel. Then I have like 10" of droop - would like to balance it out a little more.
I think you'd be happier with the setup the way it is. I'd run it and see what you think. I had a similar setup on CW's old red rig with the air shocks. Worked pretty well for crawling.
In the front you only had 3 or 3.5" of compression? Seems like I should get at least 5 or maybe 6" compression. What's the common rule - what percentage of the shocks travel should be in and out? Is it 70 droop 30 compress or 60/40? I read it somewhere a long time ago. I guess with a 14" travel shock at 30% it's only 4-1/4". I will get some better measurements tomorrow and see exactly what I do have as-is.
Nah, you don't need 5 or 6". Heck, I have 6-7" on the front of the racer. For a crawler, or anything for that matter, I think lower is better. On a crawler, having the axle droop is where it is at!
Chuzie - Here are some more pics of the ram set-up. You can see where I've already drug it over a rock so a skid plate will be in the future.
Well, I tried, but the new forum won't let me upload through the "Manage Attachments." Tech support please!!! It just says Upload failed - no reason given. I resized it to the same size I always have in the past to upload.
  Project Mall Crawler broncosbybart 11 4,082 12-23-2011, 11:21 AM
  My 70 Sport Project..."Nothin' Fancy" ncsubronc 11 3,676 10-24-2011, 02:15 PM
Last Post: 73Bronc
