C- Wedge bushings
Confusedcratchhe:Confusedcratchhe:
chuzie Wrote:If it worked so well Matt, why did you have to do it many times?????????
BTW folks, I HAVE ARRIVED. The day has finally come when Matt actually agreed with something I suggested. This is it; I have peaked.
Wow chuzie Wow
obviously they weren't all mine!! Since you bring it up I want to QC your wiring workConfusedcratchhe:
Clay if your tires have sat or not been balanced in a while its worth having that done. An alignment is a good starting point before doing much else.
U cant QC what you can't see! :O
chuzie Wrote:U cant QC what you can't see! :O
Is that because it's hidden under the rats nest?
broncomatt Wrote:obviously they weren't all mine!! Since you bring it up I want to QC your wiring workConfusedcratchhe:
I have balance beads I need to throw in them.
Balance beads could exacerbate an already unstable setup.
  Pitman arm bushings? and a couple other suspension ?'s knoxville714 3 3,163 09-16-2016, 08:10 AM
Last Post: Deltabronco
  RADIUS ARM BUSHINGS chulo2004 4 3,369 08-21-2009, 11:12 PM
Last Post: chulo2004
  axle pivot bushings chulo2004 3 1,270 12-09-2008, 11:51 PM
