09-29-2020, 06:31 PM
Would Factory Exhaust from a 1995 bronco 5.0 fit a 1995 bronco 5.8L I see Bronco Graveyard sells Magna Flow part# 93307 for a 5.0
Thanks for your help.
5.0 vs 5.8 Factory Exhaust
09-30-2020, 02:47 PM
While the heads are the same so they would bolt up. The 5.8 is a windsor block. That has a wider deck. The angle MAY be different. Certainly the Y pipe will not fit.
Single or Dual exhaust? | Broncitis | 6 | 2,057 |
05-07-2015, 10:29 PM Last Post: Broncitis |
Exhaust question | Casey835 | 27 | 7,139 |
08-16-2013, 06:03 PM Last Post: blazinchuck |
exhaust backfire? | berg bronco | 19 | 4,121 |
07-15-2010, 11:12 PM Last Post: berg bronco |
Help !!! Caused an exhaust leak | johnpaulgolf | 10 | 3,154 |
09-25-2009, 09:46 AM Last Post: johnpaulgolf |
