cutting brakes
Just curious how they work? Does any one here use them? Do you have push the brake pedal in to use them?
There are usally 2 floor mounted levers that lock up 1 rear wheel at a time.It doesnt work well with a Spool though.
03 Honda Shadow Spirit
The only time they would work well would be with a twin stick transfer case shifter. And again not with a spool. Or on your sand buggy. Pretty common there.
Tim
[Image: 2rwp56f.png]
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,594 01-11-2014, 12:26 AM
  Brakes!!!! help needed!!!!!!!!!! Brushmaster 9 7,844 09-06-2012, 03:18 PM
  Disc brakes dixieboyz13 3 3,008 08-19-2011, 10:53 PM
  Brakes bled and pedal goes to the floor but I do stop... sort of. chuzie 70 25,403 02-07-2011, 10:20 PM
  Early Bronco Brakes? Errorhead 7 5,205 09-18-2010, 10:18 AM
  Need advise on cutting a hood cuz1 5 4,410 06-11-2009, 12:07 AM
Last Post: 744x4
  cutting edge suspension for SAS DocLewis 8 7,852 03-25-2008, 11:34 PM
Last Post: johnski
  rear disc brakes***HELP*** blazinchuck 24 11,126 12-30-2007, 03:15 PM
