Late 70s Cadi rear disc brakes for 77 banjo rear end
I may have stumbled over a deal with some Cadi rear disc brakes and wanted yaws input on them. The deal includes Backing plates, calipers and dust shields. Is this a good conversion? Will the emergency brake still work?
Thx, Matt
I think all u can use is the calipers and maybe the cables. Nothing else bolts up
Sent using my HTC ONE via Tapatalk
Also new calipers can run $100-120 loaded
The seller is sending me some pics so as soon as I get them I will load them up. He mentioned that the plates will bolt up to my rearend. I'm only spending $40 for all the items mentioned above. I'm not sure if that's too much, I thought it was cheap. I know I will need rotors, do I have to stick with Cadi rotors?
Thx for your help Chuck! Greatly appreciated!
Sale is on hold at the moment. Want to get more feedback from you guys first. If I can't get the E cable to work then what's the point? I don't have huge tires so my big drums should be just fine for skinny 33s right?
look at it this way matt, you still get cars/trucks today with drum brakes. drums are just fine...and they will do a good job if set up right. disc are great because less heat, wont fade going thru water and do a better job stopping imo. as for the cables...i just installed a caddy swap from bc to tommys rig. i dont know if the cables are custom or stock from a caddy to make them work with bronco pedal and lead cable...but if you cant get the stuff for $50 walk away...you can get weld on brackets, new calipers, and cables from a vendor and probably be in it for under$350 maybe
It all depends on what you want in an e-brake. The caddi calipers have a provision for an e-brake but it is worthless. If that is your main concern, walk away. That price is cheap. As Chuck said, BC makes a kit. The rotors come off of a CJ Jeep, IIRC. The calipers are very expensive ($120 each), so you could always turn around and sell the stuff for more. You'd be very lucky if it all bolts up.
there is a cadi disc tech article on classic in the tech articles section bottom right of homepage
My Build Thread-
Thx nick, I saw that a while back. I decide just to keep the drums bc really they are just fine for the tires I have. I need to get with you on the axle rebuilds, both axles are sitting in a corner of my garage. I'd like to catch up with you before I leave.
Been doing some disc brake research too.......Just ordered some new caddy calipers for a swap on the 4door......
:xyxthumbs: ROCKNROLL!!
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,091 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,533 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,749 06-20-2015, 12:18 AM
  rear main seal snipes243 5 5,049 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,849 03-06-2014, 08:09 PM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,168 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 7,891 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,843 12-22-2012, 05:34 PM
  5.0 rear main bearing... is it going out??? chuzie 16 8,378 12-18-2012, 04:52 PM
  Looking for Troubleshooting Tips for a 79' Bronco Rear Window (Powered). UTFLIWGYA 5 6,918 10-29-2012, 05:41 AM
Last Post: UTFLIWGYA
