cutting edge suspension for SAS
I've been thinking of taking my 1978 Big Bronco project and putting my Dana 60s under it. What would be cutting edge suspension for such a project? Doc
Dr. Bruce Lewis; President, East Coast Bronco Registry (#649)
I've been thinking about 4 linking my EB, so maybe that would be a good direction. It's hard to beat that stock setup,Chuck
blazinchuck Wrote:I've been thinking about 4 linking my EB, so maybe that would be a good direction. It's hard to beat that stock setup,Chuck
One of my very good friends, Brent Broberg, just graduated from NASCAR Chassis Fabrication school and is now the chief fabricator at James Duff Enterprises in Knoxville. His younger brother, Brian, and he designed Duff's new rear 4-link. Take a look at their work -- you will be mightily impressed! 8) Doc
Doc, I believe it is hard to beat a set of Cage arms.
Here is a good article I found on 4 link front suspension: http://broncohio.com/tech/fourlink.html
BUCKETOBOLTS Wrote:Doc, I believe it is hard to beat a set of Cage arms.
Thanks for the link. I'm looking at extended radius arms for the 1979 F350 Dana 60 that I have, but a fourlink front and rear would be killer! :twisted: Doc
I think 4 link fronts on a fullsize bronco are pretty hard to do. I would do a 3 link, coilovers. Or you could even get some extended wristed radius arms and coils. Theres some guys getting insane flex out of that.
As for the rear, you can get alot of flex by just using some different rear springs. try some 2wd 57" ford rear springs back there, or make you own pack.
However, a 4 link rear would be SWEET
Hey, Doc
Slims runnin tuns if I ain't mistaken. He's gettin great flex out of the stock set up with Duff arms. Not sure what springs though.
66 Rockrawler, 66 RestoMod
[SIGPIC] [/SIGPIC]
Use the extend radius arms with duff shocks and springs. Keep the rear leafs. Simple simple. I am tired of tuning my 4 link.
I've got deaver superflex coils with cage arms and it's working quite well for me...
[Image: img_1504.jpg]
'95 Bronco with stuff, details here: http://www.supermotors.net/vehicles/registry/2805
  Pitman arm bushings? and a couple other suspension ?'s knoxville714 3 5,049 09-16-2016, 08:10 AM
Last Post: Deltabronco
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,981 01-31-2016, 03:55 PM
  8 lug and SAS Ron Burgandy 4 3,734 09-25-2012, 12:24 PM
Last Post: Ron Burgandy
  suspension seats snipes243 4 4,419 03-04-2011, 01:26 PM
  suspension setup GOODOLEBOY84 0 2,534 01-18-2010, 01:25 PM
Last Post: GOODOLEBOY84
  Need advise on cutting a hood cuz1 5 4,415 06-11-2009, 12:07 AM
Last Post: 744x4
  cutting brakes snipes243 2 3,259 02-15-2009, 09:41 AM
Last Post: Timstrk
  2.5" Suspension Lift JimR 20 10,428 08-21-2008, 12:03 PM
  Pictures from my SAS Ogeechee 4x4 13 9,726 05-15-2008, 05:18 PM
Last Post: Traveler
  Compare Suspension system MFGRs chuzie 11 5,553 03-24-2008, 06:51 PM
