Who is using Surplus Center for ram assist cylinder?
Looking to replace my ram as it leaks even after complete seal replacement. I do not want to spend $200 so I came across model 9-7258-8 from Surplus Center.
Is anyone using this model?
Any concerns?
Here is the direct link. Thx
https://www.surpluscenter.com/Hydraulics...7258-8.axd
chuzie Wrote:Looking to replace my ram as it leaks even after complete seal replacement. I do not want to spend $200 so I came across model 9-7258-8 from Surplus Center.
Any concerns?
What are you running right now?
Running some numbers at 1,000 psi supply with different rods for push / pull.
5/8 rod = 1767 / 1460 psi = 307 diff
3/4 rod = 1767 / 1325 psi = 442 diff
1.00 rod = 1767 / 982 psi = 785 diff
Should I be concerned about psi difference in pull between the different rods or is it pretty much nominal?
I am running an unknown brand 1.5x8 with 5/8 rod.
I have a surplus center ram on the racer. Forget which one. I'm not in love with it for high speed back and forth turning. No issues with it turning in the rocks. I do think you get what you pay for.
I am hesitant about cheaping out especially since i use it on the street.
That is my thought as well.
The more I educate myself on the subject of hydraulic cylinders, the more I feel I may have an alignment issue damaging my rod seal.
When I get back to CHS, I am going to closely inspect the cylinder and my mounting job.
  1996 5.8 L Engine Rebuild- Cylinder heads jrshepherd 0 3,419 07-17-2011, 11:13 AM
  hydro assist smitty 9 5,639 05-15-2009, 08:56 PM
Last Post: Timstrk
  Master cylinder help snipes243 9 4,560 08-20-2008, 12:17 AM
