Ford Dana 44 Question
1979 F150 Dana 44 compared to 1990 Bronco Dana 44 TTB.
Will the Hub, Bearings, and Rotor work from the 90 axle on the 79 axle?
Thanks, John
Why you ask? Trying to save some money on a solid axle swap.
Those specific parts should swap over. The easy way to tell would be to go onto advance auto parts web site. Check the part numbers on the bearings and compare years. I'm sure the hub and rotors are the same, just never bothered to try the bearings.
ive seen them all swap over before. you are going to need differant calipers though.
  Exhaust question Casey835 27 14,954 08-16-2013, 06:03 PM
  cummins to a ford small block standard trans adapter plate Rdnckdemo 2 2,508 04-14-2013, 01:19 AM
Last Post: Rdnckdemo
  Ford D.U.I. Ignition scbronco 14 11,611 09-06-2012, 06:03 PM
  dana 44 mods 64500xl 8 4,047 07-06-2012, 08:44 PM
  1991 351W EFI Question Crawdad 4 3,885 03-27-2012, 09:05 AM
  Hard top Question 744x4 5 6,169 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,820 08-25-2011, 01:58 PM
Last Post: ncsubronc
