cummins to a ford small block standard trans adapter plate
Hi everyone,
I'm new to the forum and was hoping someone might have these items I need. I looking for an adapter from a 4bt to ford standard small block trans, I also need the flywheel. I have some items to trade and cash if possible. :xyxthumbs:
Welcome to the board.
Where are you located? We have a handful of folks on here that may be able to assist you. What vehicle is it going in?
Sorry for not getting back to you right away. Life got in the way. Anyway I'm up in Ct, tring to match a zf five speed to a cummins. I have the Chevy adapter plate and the 350 trans. Any ideas?
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,513 09-19-2018, 02:50 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,048 01-19-2017, 12:53 PM
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 6,080 05-15-2014, 11:50 AM
Last Post: rbodine
  Can firing order determine engine block size? 1st Bronco 1 2,013 08-16-2013, 06:26 PM
  Ford D.U.I. Ignition scbronco 14 11,604 09-06-2012, 06:03 PM
  USA Standard Gear? SC74 2 2,583 03-09-2012, 09:51 PM
  Horn and License Plate Light - Stupid NC State INspection!!!!! UTFLIWGYA 15 8,557 11-13-2011, 08:18 PM
  C4 Trans Dipstick Tube SC74 5 4,909 10-24-2011, 01:35 PM
  Early ford bronco? Marzialbers 2 3,918 02-04-2011, 10:48 AM
  Help identifying trans jdowns67 1 1,970 01-22-2011, 11:41 PM
