1991 351W EFI Question
A fella contacted me and offered his 91 351W efi set-up for nearly next to nothing (like $50 plus shipping). What would all do I need? Will it work on my 351W. He is keeping the motor in order to carb it, everything else is up for grabs. I think the motor is already been pulled and at his house. I asked him to get me a picture of the motor as it sits so I'll post it later on. Don't need an efi yet, but if the money is right and dirt cheap I'll jump on it if my wife gets it for me! Thx for the input!
if its from a bronco or truck, i dont think you can use the intake(too tall) your better of with a mustang or explorer using the adapter from bcbroncos i think.
get everything from a mustang...not sure i would fool with that 351efi. hopefully others will know more
He just told me its from a 91 Bronco w no ECU box, no PS pump and no Alt. May be someone on here may need it.
The injection system on that model isnt ideal for an eb. Too tall and not very good in its own right. Like Chuck said I would stick with aftermarket type stuff. The windsor doesnt have much OE stuff you can get for it. Most mustangs came with the 5.0 which has a narrower intake. For the price I would try a holly projection or a painless system that uses the chevy tbi.
What they are saying. The 351W stuff you are looking at is all speed density (not MAF). You wouldn't be able to modify it easily to work in an EB, as the intake is way too tall.
  Steering shaft Extension Question??? Broncitis 4 4,657 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 14,946 08-16-2013, 06:03 PM
  Efi and stock fuel tank snipes243 3 2,945 12-11-2012, 03:28 PM
Last Post: Carolinaoffroad
  EFI wiring harnesses BucknEB 16 8,963 07-04-2012, 08:32 PM
  Specs for 351W motor mount bolts? 73Bronc 11 6,062 09-27-2011, 11:36 PM
Last Post: 73Bronc
  Hard top Question 744x4 5 6,165 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,816 08-25-2011, 01:58 PM
Last Post: ncsubronc
  Fiberglass Dr Insert Question 744x4 5 3,694 08-10-2011, 01:24 PM
Last Post: dixieboyz13
  5.0 EFI upgrades? blazinchuck 4 3,080 07-25-2011, 10:57 PM
Last Post: nhopman
  9" pinion question scbronco 10 6,058 01-07-2011, 08:23 PM
