Ford Automatic Transfer Case Wiring
I have a 2000 F150 2x2 and I’m getting ready to do a SAS with a new transmission and an automatic transfer case. What I’m looking for is how to wire the transfer case to the dash switch and power, etc. Any one have an idea or a Ford wiring diagram?
Thanks.
I know this is not a Bronco but maybe someone can explain how the wiring should work between the switch and the case. I can't believe there is a big difference between the 80's/90's and 2000 wiring.
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,505 09-19-2018, 02:50 PM
  New Wiring for a 351 knoxville714 10 10,181 02-23-2017, 03:01 PM
Last Post: tcb3078
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,028 01-19-2017, 12:53 PM
  Adjusting Transfer Case Shifter jdowns67 1 1,671 10-27-2014, 01:49 PM
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 6,063 05-15-2014, 11:50 AM
Last Post: rbodine
  t-shift t-case won't go into 4-lo scbronco 3 3,941 04-01-2014, 09:54 AM
  Cleaning up Wiring jdowns67 0 1,710 12-26-2013, 11:53 AM
  what transfer case Ron Burgandy 4 3,561 08-18-2013, 11:06 AM
Last Post: 1st Bronco
  cummins to a ford small block standard trans adapter plate Rdnckdemo 2 2,497 04-14-2013, 01:19 AM
Last Post: Rdnckdemo
  Ford D.U.I. Ignition scbronco 14 11,562 09-06-2012, 06:03 PM
