Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral????
77 EB, 3 spd auto, 302 with carb
So, The EB starts fine, drives like a champ and idles normally.....but as soon as i shift to Neutral or Park, she dies.....sometimes chokes and dies.....
Is this a "mechanical" issue or an "electrical" issue?
Thoughts???
Thanx guys
Likely mechanical. The only electrically related issues would be a NSS but that only prevents starting in neutral or park so that is not an issue.
I would lean toward a vac leak. Does your exhaust smell rich? What is your idle speed in park and drive? I don't see how your TC could cause this as it would be the opposite and die in drive.
......seems easy enought to test nuetral safety switch...find where the nuetral safety switch plug is by the steering column where it comes up from shift lever on the tranny. Start the truck and then unplug the switch and see if it does it......sounds like it is shorting the hot side of the coil, which I could see might happen if it was '75 or earlier with points, '77 should be electronic, right?
:xyxthumbs: ROCKNROLL!!
Test light or volt meter on the coil would tell ya, too!
NSS only comes into play when cranking. It just prevents from starting in gear, cant interrupt ign signal while running. It truly sounds like a carb issue, probably a vacume leak. Try spraying around the carb and engine vac lines with carb or brake clean. If the rpm picks up you have found your leak. Do this checking with the air filter housing on to get a true reading of a leak.
All: Thank you
Chuzie and Bronco Matt: Concur. The exhaust is rich and the idle is fine. I am going to have to check the vac lines as you described. Brilliant idea.
Bronco Biff: My 77 has points and a 2-brl carb. The EB will start in Park and Neutral. I'll have to try to locate the switch you are describing.
More to follow......as the adventure continues........
I also would lean towards vacuum leak. Follow the thin rubber hose that goes from the modulator to the back of the carb...
  Engine help snipes243 12 6,450 02-21-2014, 12:06 AM
  Can firing order determine engine block size? 1st Bronco 1 2,013 08-16-2013, 06:26 PM
  5.0/nv3550...engine now dies at stops*help* blazinchuck 14 7,026 06-09-2013, 10:50 AM
  cummins to a ford small block standard trans adapter plate Rdnckdemo 2 2,504 04-14-2013, 01:19 AM
Last Post: Rdnckdemo
  Park Brake lever idea dixieboyz13 1 1,987 02-28-2012, 11:39 PM
  C4 Trans Dipstick Tube SC74 5 4,908 10-24-2011, 01:35 PM
  1996 5.8 L Engine Rebuild- Cylinder heads jrshepherd 0 3,417 07-17-2011, 11:13 AM
  Engine Rebuild. 1996 5.8 L jrshepherd 0 1,738 05-05-2011, 02:02 AM
  Help identifying trans jdowns67 1 1,969 01-22-2011, 11:41 PM
  Please educate me on 3 speed trans RAT & RAN? Mill Knob 11 9,518 01-11-2011, 10:34 PM
Last Post: Mill Knob
