Hard top storage.
I finally put my soft top on my Bronco and was needing a place to stor my Hard top with out stepping over it. So I done a little thinking and came up hanging it up in the garage.
I came up with some of the Idea after seeing Josh (Berg Bronco) set up in his garage.
So what do you do with your hard top when it is not on your Bronco?
nice I dont want to see that thing on youre bronco any time soon:hysterical:
berg bronco Wrote:nice I dont want to see that thing on youre bronco any time soon:hysterical:
Or my Wife's car...:rubeyes:
I need to come up with a solution as well. I guess with the cooler weather around the corner, I have some time to figure it out.
Mill---how did you get your top raised? It looks from the pics like you used some ratchet straps; but did you ratchet each corner individually or use some other method? I have been looking into this for some time; just need a good plan and some motivation.
“Not the victory but the action; Not the goal but the game; In the deed the glory”
mjmcbride1 Wrote:Mill---how did you get your top raised? It looks from the pics like you used some ratchet straps; but did you ratchet each corner individually or use some other method? I have been looking into this for some time; just need a good plan and some motivation.
I took and put the boards under the hard top and then ratchet each one alittle bit at a time untill it was up where I wanted it. Let me know if you need more pictures.
  wanting a BC top! blazinchuck 8 6,060 03-31-2013, 03:28 PM
  Bestop Soft Top Questions broncosbybart 0 1,662 03-13-2013, 02:14 PM
  Cradle for temporary engine storage wormhole 4 2,293 03-07-2013, 07:33 PM
  78/79 Soft Top?? cyoung 2 3,349 12-08-2012, 07:13 PM
  Hard Top Brohawk75 2 2,535 11-30-2011, 12:17 AM
Last Post: Brohawk75
  Hard top color code? N747JB 8 3,806 10-29-2011, 07:43 PM
  Rampage Soft Top vs. Bestop kphan43 7 6,990 03-14-2011, 02:50 PM
Last Post: kphan43
  Optima Battery Mount: Help me pick a top! Crawdad 12 5,466 01-30-2011, 08:58 PM
  Old top modifacation to half cab top. huntingflastyle 3 2,426 08-15-2010, 12:09 PM
Last Post: huntingflastyle
  Top josephitguy 4 3,215 03-05-2010, 12:20 PM
Last Post: josephitguy
