brake problems
Replaced my front brake lines and then had to bleed the brakes. Me and my buddy did this successfully but a day or so later I took it around the block and the brakes were spongy again. This was the first time I drove it since bleedin, any ideas?
maybe coming from the rear brakes. thats what gives the firm pedal.
Bleed the entire system again in the following order (RR, RL, FR, FL). A few pumps of fluid with no bubbles does not mean air is not is the system so Do the procedure twice and make sure there is plenty of fluid in the master each time.
thanks for the input guys, i will try this one more time, let u know how it turns out:xyxthumbs:
Might as well replace the 3 rear lines as well (if you haven't already done so). They're cheap and the new ones will make a difference--I could literally feel the old ones swell up when my daughter pushed the pedal down on her '90---very un-good. Also it's very simple to pull your brake booster and check the rod length to make sure it's correct. Look in your Haynes manual and it'll clue you in on how to do it---takes less than 5 minutes if you have your wrenches & sockets handy..........
I support gay marriage. As long as both the chicks are hot.........
  Parking brake snipes243 24 16,455 11-29-2015, 06:21 PM
  Manual brake push rod??? chuzie 13 8,588 01-06-2014, 03:04 PM
  Chevy Conversion Brake Calipers Jbass 10 6,105 02-15-2013, 07:56 PM
Last Post: Jbass
  Brake problems after the 5.0 swap. BucknEB 10 5,572 10-29-2012, 03:07 PM
  Park Brake lever idea dixieboyz13 1 1,988 02-28-2012, 11:39 PM
  Soft Top problems!! jollygrngiant 10 5,439 11-22-2011, 12:49 PM
  90 Transmission Problems 2000F150SAS 1 2,333 06-21-2011, 10:53 AM
Last Post: 2000F150SAS
  Pertronix Ignition Problems. Mill Knob 13 6,892 09-09-2009, 01:32 PM
  No Brake lights.. Mill Knob 28 12,296 08-06-2009, 09:37 PM
Last Post: Mill Knob
  Bushing source for EB brake booster chuzie 3 4,159 07-12-2009, 08:10 PM
