90 Transmission Problems
Ok we have a problem, my sons 1990 Bronco 302, AOD, with SAS, 4:88’s, and 38” tires.
He went to the beach this weekend running 60-65 mph on the interstate, got there with no problems. Coming home the with truck it start shifting funny, it would not shift into 3rd until it hit 3000-3500 rpm it also would not pull its own weight in overdrive climbing small grades on the interstate. He said if he gave it more gas it felt like it was slipping or just not accelerate. I checked the trans. Fluid and it smells fine, has good color, and no metallic in it. The fluid and filter was changed last year.
The truck just started to have this problem, out of no were!!
shifted 1st to 2nd around 3200rpm
shifted 2nd to 3rd around 3500rpm
when in 2nd if he lifted off the gas the truck would drop to idel rpm
when in 3rd if he lifted off the gas the truck would not drop any rpm's
Besides the shifting problems he had anti freeze pushing out of the overfill bottle, not a lot but some.
We had to pull the distributor to replace the ignition module so I know the timing is not exact but close, could this have anything to do with our shifting problem?
I was told to check the throttle pressure cable the runs from the throttle body to the transmission, but everything looks fine.
Is there anything I can check? Any ideas?
Thanks, John
John - 2000 F150 SAS
I just got off the phone with a NC4X4.com Transmission Vendor who has been helping us and he thinks the 3rd/4th band is slipping. So we are taking it to him Monday so he can check it out. If it is the trans it will be $800 for a rebuilt trans, converter, and a 4x4/towing valve body. That's if we bring it to him. Plus this will be the time to replace the transfercase with the new manual case we have.
JayT if you have a electric shift transfercase I may have one for you out of John's truck since we are going with a manual transfercase.
John
  Brake problems after the 5.0 swap. BucknEB 10 5,652 10-29-2012, 03:07 PM
  Soft Top problems!! jollygrngiant 10 5,507 11-22-2011, 12:49 PM
  brake problems fordfan 4 3,451 09-11-2010, 11:45 PM
Last Post: Ricky B
  Pertronix Ignition Problems. Mill Knob 13 6,970 09-09-2009, 01:32 PM
  90 Bronco Automatic Transmission Question 2000F150SAS 3 2,512 06-15-2009, 02:12 AM
Last Post: supertoyota88
  Transmission and Transfer Cases in Ford Fullsize trucks... Mtrhd0024 8 4,880 05-11-2009, 10:38 PM
Last Post: bone collector
  C4 Transmission Temp probe location? High Pressure 6 4,234 06-22-2008, 07:56 PM
