Copper vs Aluminum radiators???
A couple of guys on Classic Broncos have made their points that copper is more efficient than aluminum at transferring heat away. I have a very hard time believing this is true. Am I wrong?
well, everyone that i have ever seen race in any sport...runs alum. i find it hard to believe also.
Clay is studying heat transfer, maybe he can pipe in here. I wll say that alum is cheaper and lighter- probably the reason it is used so much now. I think that you should be ok with your new rad. Just have a good shroud on it. I have an alum Howe in the crawler w/the 351. It gets hot sometimes, but I don't have a shroud on it. It usually does fine, and it is always slow speed stuff.
  Aluminum Radiator johnpaulgolf 15 7,834 07-18-2008, 10:26 AM
