Installing 5 1/2" lift........
Well I bought wild horses rear springs. A little tough to install. Now I need to rotate rear axle for better pinion angle. I got the 4 1/2 front springs. Also the track bar riser bracket. So I should have this done before the next meeting. Maybe.. I really just need to know if the caster is going to be ok. And I think the front drive shaft will be allright.
77 Bronco, 5.0 Trick flow heads, roller motor, L&L headers, Protofab family cage, Protofab rear bumper w/ Tire and cooler carrier,Beard seats, Rhinoed tub,33" swampers, PSC ported steering box with soon hydraulic assist.
Jeff, you might need some axle shims for the rear. The axle yoke needs to be almost in a perfect line to the shaft, just about 2 degrees below inline.
as for the front, what radius arms do you have and caster bushings are you running? You may need some better caster bushings to help with driving and drive shaft angles. If the caster isn't right it can be hard to steering, not return back to center when you turn and let go of the wheel,etc.Chuck
Instead of buying those shims I bought some new axle perches. I'll just cut the old ones of and spin the axle and weld those new ones on. I think it will be better than taking those springs out. I had to use ratchet straps to stretch those springs in place. I don't want to go through that again. As far as the front I bought the 7degree bushing kit.
Instead of buying those shims I bought some new axle perches. I'll just cut the old ones of and spin the axle and weld those new ones on. I think it will be better than taking those springs out. I had to use ratchet straps to stretch those springs in place. I don't want to go through that again. As far as the front I bought the 7degree bushing kit. Stock radius arms.
I just wanted to make sure everybody got that post. @##$@ Dialup!
  Body lift issues dixieboyz13 4 2,943 09-14-2011, 12:58 PM
  lift opinions firefighter2134 12 4,991 04-26-2010, 06:55 AM
  My first ford lift. clarkjw24 7 4,136 08-08-2009, 03:28 PM
Last Post: clarkjw24
  tire sizes and lift krawlin 5 3 2,510 11-30-2008, 01:23 AM
Last Post: 69bronco
