Body lift issues
Well, I ran into some issues with my body lift before I could even get started. The PO had fabricated some new floor pans and riveted them into place. Needless to say, they cover the body mount bolt. The old pans are still underneath, and have a good bit of rust through. Looks like this will have to go on the back burner until I can get new floor pans and intall them properly so that the block doesnt push through the floor. Anybody got any other ideas...
hmmmm. Use a hole-saw bit to cut through the "new" floorpans around the bolts?
mine are the same way, I drilled the rivets out removed the bolt. did the body lift then re riveted the floor panels back in. But my floor are not horrible just holy.
The floor support braces are solid as can be. I might try drilling out the rivets in order to get the bolts out and then putting them back in place. I'm sure I can find a way to get it done, just dont want it to look like crap when finished.
if ya dont want it to look like crap...remove the rivets and floor, then get the bolt out,do the body lift...then cut whats left of the original floor and fit the removable floor in place to welded in right and make a new hole for the body bolt
  nv3550/clutch issues... blazinchuck 11 6,273 03-15-2012, 09:33 AM
  Body is off! scbronco 49 18,633 05-06-2011, 10:59 PM
Last Post: NGABronco
  steering issues? blazinchuck 6 4,392 01-21-2011, 07:50 PM
  lift opinions firefighter2134 12 4,991 04-26-2010, 06:55 AM
  My first ford lift. clarkjw24 7 4,136 08-08-2009, 03:28 PM
Last Post: clarkjw24
  Body armor......quarter panel protectors bigjake6 4 2,998 07-15-2009, 10:23 AM
Last Post: bigjake6
  tire sizes and lift krawlin 5 3 2,510 11-30-2008, 01:23 AM
Last Post: 69bronco
  Air conditoning issues tapiot 6 3,504 09-15-2008, 05:19 PM
  Body Mounted on Rotisserie!!!! Bighorn 15 8,277 09-09-2008, 11:21 AM
Last Post: abunchofidiots
  Looking for a solid body for a rebuild gigabytethis 0 2,153 05-31-2008, 04:43 PM
Last Post: gigabytethis
