Bronco Heater Fan Upgrade
Here is some info on swapping the stock blower fan for one that blows better, works well.
For some reason, I am thinking that Advance auto sold me the wrong cage fan. I found a part number in an old thread, called them they crossed referenced the part number I found on here, and there is one number difference (on both motor and cage fan) between the one that I have vs. what was cross referenced.
Fan I have is 35588 vs. 35587(cross ref)
cage fan I have is 35601 vs 35602 (cross ref)
They have the fan in stock but they have to order the cage and it will be here tomorrow. I will take what I have, my heater box, and figure out what the heck the differences are.
The ones they gave me was for a 78/79 chevy truck.....who knows. Hopefully I will have the right stuff to finish this upgrade tomorrow.
I already have the new chevy motor and the new squirrel cage fan. I want to use both. The new blower fan is about 1" larger in diameter and is deeper than the orginal (not sure by how much)
The larger fan will push more air than the stock fan. The motor being faster AND the fan being larger is the whole point of modification.
To stay "all Ford" I used a bigger motor/squirrel cage from a 92 F-250 and did NOT have to trim the bell-mouth inlet.Only had to trim the opening a bit larger to get the bigger squirrel cage in
I too would like to have the correct no. for the chevy items .. My motor is M847 I don't remember the squirrel cage no. But I too felt like my cage was too deep .. Making it drag on the back of the heater box .. Making min
What you probably got was the squirrel cage for th Heavy Duty heater. It is deeper than the standard Chevy heater cage. You have to specify this at Advanced Auto. Same thing happened to me.
I used the '78 chevy heavy duty heat motor and squirell cage combo, Trimmed hole only, used one existing mounting screw hole, redrilled the others. Blows well no other issues.
I upgraded to Four Seasons Part #35602 Blower Wheel
Four Seasons Part #35587 Blower Motor, I was able to adjust the depth of the fan with the fan's set screw. Only had to open the existing opening.
Since I've been asked a few times about this; I figured I'd post it again:
This is something that I have done and originally posted to the list about 6mo ago. Use the motor & cage from a 78 1/2 ton chevy pickup. Carquest part number #208971 (motor) & #209109 (cage). It is about a 30 min upgrade. You will need to cut the opening in the heater box larger. (I used a dremel tool). Use the cage as a guide. Then secure with some self tapping screws. The results are amazing. Cost under $40...
I am happy to put the Napa numbers out for everyone.
Carquest # Napa #
208971 455-1039
209109 655-1406
Okay Guys, got a question about the Heater. I have never replaced a heater core before. Other then having to deal with the posibility of dryrotten vent hose, How difficult of a task is it and are there any tricks to making it a breeze. I have already ordered the Heater core and seal kit from JBG shoud be here friday. Tim (Dirtywhiteboy)
I know SCbronco (Nick) is either in the process or finished doing an upgreade like this. He might chime in and give some thoughts. Please take lots of pics bc this is something I want to do as well.
I'm placing an order with JBG for the heater seal kit and new defrost ducts tomorrow. Thanks for the part numbers Matt. I'm going to give Napa a call and get this upgrade installed when I get home next week.
'76 Sport. 5.0 EFI b303 cam, Trickflow intake, Explorer Serp, long tube headers, BCB exhaust, C4,D20, twin sticks, TBP roll cage, 3"SL 2"BL, 33 KM2's
I found a good article today about changing the heater core, here's the link
http://www.broncohio.com/tech/heatercore.html
Sounds easy enough but might need an extra pair of hands...Dirtywhiteboy
DirtyWhiteBoy Wrote:I found a good article today about changing the heater core, here's the link
Any progress on making the upgrade?
Well I've dragged my feet ordering these parts. I just searched the Napa web site and found the parts but I think your 455-1039 part number is wrong.
Is this the correct PN# 655-1039
Is the heavy duty fan PN#655-1406 correct?
Cant tell without seeing the squirrel for reference.
  DIY 66-77 Early Ford Bronco Front Floor Pan Replacement broncosbybart 12 12,526 08-03-2014, 11:36 PM
  EFI upgrade: 55mm to 70mm MAF chuzie 1 3,174 01-08-2013, 12:48 AM
  cherokee wiper upgrade broncomatt 6 5,043 09-27-2012, 01:34 PM
  Turn signal upgrade, to the early style broncomatt 0 2,053 09-08-2012, 10:27 AM
  78/79 bronco f350 brake upgrade broncomania 2 4,548 05-04-2008, 08:45 PM
  power steering upgrade for 76-79 fullsize broncomania 0 3,524 03-25-2008, 10:12 PM
