EFI upgrade: 55mm to 70mm MAF
Power is all about how much and how fast you can suck, squeeze, bang, and blow. Not only does this apply to the 20 year old hottie at the bar, but to our engines as well.
The stock Mustang EFI setups are seriously restricted. The list of modifications is long and potentially expensive.
One cheap way to begin to lessen some of that restriction is to install a larger MAF.
The stock MAF is 55mm. Most folks spend $$$ on large aftermarket MAFs but for our applications, there is a way to save some of that cash.
You are going to need a new MAF sensor and a new MAF housing (tube).
Check out these vehicles at your local junkyard:
92-95 SuperCoupe, 70mm for 3.6's
Ford Mustang 1994-1995 V6 or 5.0L 70mm
Ford Crown Victoria 1992-1994 4.6L 70mm
Lincoln Towncar 1992-1994 4.6L 70mm
Mercury Grand Marquis 1992-1994 4.6L 70mm
94-97 Thunderbird 4.6 70mm
Those vehicles have the housing you want but not necessarily the correct MAF sensor. You want a sensor with part number F2VF-12B579-A1A or A2A. Keep in mind the sensor is secured with a security torx bit.
You can get the housing/sensor combo from LKQ for $25.
These housings are round on the engine side and square (flanged) on the filter side which is not condusive to a cone filter. The parts houses do sell an adapter for $15 so you can adapt the flange to a round filter but we are trying to save money here!
I just cut the 4 corners off and used my grinder to shape it into a circle that will accommodate a round filter.
Make sure you reset your EEC so it can relearn with the new sensor.
Enjoy!
[Image: maf.jpg]
Here is a comparison of the house before and after.
[Image: P1050003.jpg]
[Image: P1050004.jpg]
very nicely done chuzie...been promoted to TECH PAGE, thanks
  How to convert your mustang 55mm throttle body to a 65mm explorer blazinchuck 2 4,479 09-17-2017, 07:47 AM
Last Post: Kurth
  Bronco Heater Fan Upgrade broncomatt 7 6,469 11-08-2012, 07:20 AM
  cherokee wiper upgrade broncomatt 6 5,043 09-27-2012, 01:34 PM
  Turn signal upgrade, to the early style broncomatt 0 2,053 09-08-2012, 10:27 AM
  78/79 bronco f350 brake upgrade broncomania 2 4,548 05-04-2008, 08:45 PM
  power steering upgrade for 76-79 fullsize broncomania 0 3,524 03-25-2008, 10:12 PM
