Detroit Locker on E bay?
Can someone knowledgeable on these look at the Locker and let me know if it would be ok in my rear differential. Thanks
http://www.ebay.com/itm/361278889633?ite...23&vxp=mtr
Are you going 31 splines?
Sent from my HTC6500LVW using Tapatalk 2
I will likely go ahead and upgrade to 31 when i find a locker for the rear. In the future i want to lock the front but think I will need to make the front selectable. Opinions are welcome on this subject as we all know I am a beginner with this subject.
Would a nascar locker be likely to be wore out? I have found 31 spline axles on e bay which are either 31 or 34 inches and splined 8 inchs to allow them to be cut to desired length.
http://www.ebay.com/itm/FORD-9-9-INCH-CU...20&vxp=mtr Would these axles work in my 2.8 inch bearing axle and would this be a good desl?
I also have a snipe set on this warn winch,http://www.ebay.com/itm/271853876428?_tr...EBIDX%3AIT
http://www.wildhorses4x4.com/category/bronco_rear_axle i would consider these first, these are the ones i installed and they are nice, came with bearings already installed. and comes with beefy retainers.
Those retainers our suppliers sell are really nice I installed a set of them when I did the seals and bearings on the rear end of the Bronco I am working on.
I would vouch for a set of EB axles as well. Bolt on and go!
A 31 spline locker will work as long as it is for the 2.89" or 3.06" carrier bearings. They also make a 3.25" bearing but that locker is different from the other. If memory serves right they go by an "H" case or "B" case. Can't remember which is which but they don't interchange.
  Locker for TTB? JayT 11 5,241 12-08-2010, 12:16 PM
