Rjm harness and drain on battery
Getting ready for my trip this coming weekend and I noticed a drain on battery. Traced it down to one of the 4 fuses on the rjm harness. I'm reading 1.3 amps. I pulled fuses one by one, last fuse and the drain went away...down to .01. However these are connected to the 4 relays...so I pulled them one by one and never saw the drain stop...any thoughts? When I found the fuse I thought a relay was stuck...now IDK where to look
Chuck if the relays are like the ones I have been using they have a wire that is hot when the coil is energized and one hot when the coil is deenergized. I put a insulated butt splice on the wire that I am not using. Could it be possible that your relays are the same. If so are you sure that the extra wire is not grounding to the body when the relay is deenergized?
  Optima Battery warranty stuff ncsubronc 5 2,946 12-22-2011, 07:27 PM
Last Post: NGABronco
  Optima Battery Mount: Help me pick a top! Crawdad 12 5,466 01-30-2011, 08:58 PM
  5-point harness with 2" webbing? chuzie 6 3,182 01-04-2011, 03:50 PM
Last Post: abunchofidiots
  Optima battery box for 76 Bronco Crawdad 4 2,704 12-23-2010, 11:47 AM
  RJM 5.0 Harness Guys... blazinchuck 7 4,017 09-07-2010, 03:59 PM
  new wiring harness option? blazinchuck 6 3,349 08-17-2010, 12:20 PM
  Battery jrshepherd 8 3,602 11-09-2009, 09:32 AM
  Wiring Harness LUKE/KANE7707 10 4,657 10-09-2009, 12:02 AM
Last Post: wormhole
