04-27-2008, 10:36 PM
ok so why cant i put a 35x12.5 fit on a 15x8 rim? can you technically do it but if just rounds the tire?
question
04-28-2008, 08:32 AM
I've seen it done before. It just draws the sidewalls in a bit. You can compensate a bit with lower air pressure to make the tire ride flat. And a 35 is more for giving than a shorter 33. If you look at the specs for most 35x12.50's the tread width is most likely only about 9-10". The section or width across the middle of the sidewall is what give it the 10.50.
04-28-2008, 12:28 PM
sweet, thanks, i think the rims that ive got are 15x8, if not i could get some real cheap!
| Quick Transmission Fluid Question | 2000F150SAS | 1 | 2,036 |
08-06-2011, 03:49 PM Last Post: jrshepherd |
| Got a question for you fullsize folk! | Mtrhd0024 | 3 | 3,330 |
07-17-2010, 09:20 PM Last Post: Kristopher |
| 79 Bronco Radius Arm Question | 2000F150SAS | 4 | 2,966 |
08-17-2009, 06:40 AM Last Post: 2000F150SAS |
| D44 question | john90 | 2 | 2,779 |
08-12-2009, 09:42 AM Last Post: bucketobolts |
| have a question all help needed | stangman | 3 | 2,719 |
03-15-2009, 07:09 PM Last Post: Wrenchbender |
