Gearing and Crawl Ratio's
Ok I've been doing some searching for the right set up for better "crawling"
I've been getting with Chuck about buying his axle's(which I will when he finds new ones) and kickin around new gears ect.
This is some info I've recently learned.
I now have a T-Shift D20 and a RAT 3 speed and 3.50 gears w/34"tires
Chuck has a NP435 with a J-Shift D20 and 4.56 gears w/ 38.5"tires
This is a PM I sent Chuck talking about my situation
I did some research...here is the numbers
RAT 3 speed 1st=3.41 2nd=1.86 3rd 1.00
NP435 4spd 1st=6.69 2nd=3.34 3rd 1.79 4th=1.00
T-shift D20 low=2.46
J-shift D20 low=2.34
so mine now = 29 to 1
my D20 w/NP435= 57 to 1 (real soon)ASAP
mine w/ 4.88 gears = 40 to 1
mine with your axles = 38 to 1
my D20 + NP435 with your axles = 75 to 1 (future mods)
yours now = 71 to 1
so you are the man again the cheapest fastest way to crawl will be the NP435 hands down.
thanks bro
Do you already have a 235 or are purchasing one?
I need to find a NP 435 not a 235...whats up stranger?
If you run what I am you'll end up with 80 to one well 80.3. Np 435- 4.88 gears and 2.46 Tshift t-case. Don't forget to factor in you tire size also. This set up with 37's would be alot different than this set up with say 44's.
66 Rockrawler, 66 RestoMod
[SIGPIC] [/SIGPIC]
66gasgrill Wrote:If you run what I am you'll end up with 80 to one well 80.3. Np 435- 4.88 gears and 2.46 Tshift t-case. Don't forget to factor in you tire size also. This set up with 37's would be alot different than this set up with say 44's.
Thats sweet "gas" 80 to 1 is sick slow crawling.
How do the tire sizes affect the ratio's?
How do I put that(tire size) info in the equation?
Tire size doesn't change your actual crawl ratio. It changes your effective ratio (what it feel like) if that makes sense.
Say your setup at 80:1 crawl. you will still have an 80:1 crawl ratio whether your running 31's or 44's but they won't feel the same. See what I mean kinda?
Check this site, maybe it explains it a little better. If not it still has some good info. HTH.
http://www.4lo.com/calc/geartable.htm
[SIGPIC] [/SIGPIC]
66gasgrill Wrote:Tire size doesn't change your actual crawl ratio. It changes your effective ratio (what it feel like) if that makes sense.
Don't know a great deal about this crawling stuff but that was well said..:xyxthumbs:
'77 EB, 2.5" SL, 2"BL, Cummins 4bt, C4 w/Art Carr manual Valve Body, 35" BFG KM2s
http://www.youtube.com/watch?v=M_HqhiW38ik
I always think of a 18 spd. bicycle when I think about gearing in a truck. That way you've got your 3 main gears (tranny, t-case, axles) plus 6 sub-gears (trans. gears, t-case high/low) on each main gear.
As for tire size, it takes more to turn the bigger meat. Just like on a bicycle, it takes more effort to turn a larger tire (especially off of the start) than it does a smaller one.
JP, I would go with lower axle gears. My rule has always been with 33" = 410 or lower, 35"=456 or lower and 38" and up 513 gears. I would not rely on trans and t-case just to make the ratio.
Just my 2c.
I started out with the NP435, a T shift case, 4.56's, and 35" tires. With the original 302, I could let the engine idle(800 rpm) in low gear low range, and it was hard to stall the engine with manual brakes. I had several stumps in the yard I used to play on by letting it idle up and across them.
  Determine gear ratio chuzie 17 12,543 07-13-2009, 10:15 PM
  whats your gearing combo and do you like it ????? broncomania 13 6,724 06-14-2008, 01:25 AM
Last Post: 66gasgrill
  Gear Ratio??? BroncJr 9 7,540 03-31-2008, 08:17 PM
