89 F-150 hubs
well this weekend i started changing my rotors and brakes on my 89 f150. You have to take the hub off to take the rotor off. that's where the fun started. i can't get the bolts/screws out of the hub housing!:banghead:
I tried everything but cutting them out! how do i get them out?
pb blaster and a couple hour anger management break...and then try, try, try again hopefully they won't break...put um back together with anti-sieze
Probably didn't help...but taking a break always seems to help me
i soaked in them in pb overnight. and took a long break, i'll try again tonight maybe.
well still no go. and it's an odd size, 9/64
You needing to remove the allen bolts for the hub? Have you tried taking a punch that will fit down in side the head and giving them a good whack? Some times a good jar will loosen them up.
havn't tried that. i'll give it a try!
well figured out what was wrong, somebody really coated them with loctite. i had to drill the heads off.
i swear if i knew who worked on this thing before my dad got it, i would smack them. they put somethin like loctight on the inner wheel bearing seal. luckily local auto parts store had more.
obxbronco Wrote:i swear if i knew who worked on this thing before my dad got it, i would smack them.
I know the feeling. Cleaning up PO's crap work (not yo9ur dad - whoever did the locktite) is the majority of the PITA on most jobs. Good Luck getting it done.
well, worked on it somemore lastnight, trying to get bearings lined up right. got frustrated, so i quit probaly for the week. i got to work 7 at night to 7 in the morning the rest of this week.
