Bent leaf spring
My driver side leaf springs are bent pretty bad any advice...Confusedcratchhe:
Anybody got some stock ones I could get?:notworthy:
Any advice and comments
thanks JP
:biggthumpup::popc1:
i got a pair you can have... but i'm in alabama. i'll be meetin broncomainia in a few weeks to buy some tires we could set somthin up then.
Give um to Mike I will see him soon!!!
Thanks...
For an EB right?
My only advice is to stop bending them. Smile
Before you install new spring I would determine the cause of the bending in the first place, otherwise it could happen again. You weren't jumping your truck or something...right?
Mike, make sure you charge JP for shipping!!!
chuzie Wrote:My only advice is to stop bending them. Smile
I think it got caught up on a rock...Confusedcratchhe: imagine that...no jumping but some hard a** wheelin...I had an issue earlier in the day where it almost came out of the hanger(two of um did) and then it corrected itself...just old and overworked is my geuss...:banghead:
Do you have 11 packs under there right now? Make sure the ones you are getting are the same that you have now or you may change the level of your rig. Just a thought.
Way to show that rock who's boss. Did you take a Sharpie and write "JP was here...BEOTCH" on your rock?
Stock...5 or 6 ...can't remember
there stock springs from under my 76'
perfect!!!
any thing else your lookin for i've got a boneyard i'm tryin to clean out.
  Rebuilding used rear leaf springs Crawdad 5 6,561 12-12-2016, 11:54 AM
  Bent Axles jdowns67 19 10,671 11-28-2015, 11:05 AM
  leaf springs dixieboyz13 4 3,097 08-31-2011, 10:22 PM
Last Post: NateMob
  leaf springs snipes243 2 2,690 02-24-2011, 10:12 PM
  c4 trans filter change spring and thing! jrshepherd 2 3,663 03-13-2010, 08:12 PM
  leaf springs berg bronco 4 2,819 10-24-2009, 10:19 PM
  Looking for Spring Shop 2000F150SAS 5 3,557 09-24-2009, 09:52 AM
Last Post: 2000F150SAS
  Spring and leaf opinions? Errorhead 8 4,278 05-08-2008, 07:28 PM
Last Post: Errorhead
