c4 trans filter change spring and thing!
I just removed the trans filter and realized there was a spring/ thing that fell out. Does anyone know which way it goes back in? Thanks!Confusedcratchhe:
I believe that is the pressure relief valve. You can take some Vaseline and cram it in to the valve body to secure it till you get the filter back on. It should go in with the spring toward the filter and the flat part of the valve toward the valve body.
[Image: C4-valve-body-02.jpg]
u are a life saver! She is a runnerSmile
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 6,094 05-15-2014, 11:50 AM
Last Post: rbodine
  cummins to a ford small block standard trans adapter plate Rdnckdemo 2 2,512 04-14-2013, 01:19 AM
Last Post: Rdnckdemo
  C4 Trans Dipstick Tube SC74 5 4,929 10-24-2011, 01:35 PM
  Help identifying trans jdowns67 1 1,975 01-22-2011, 11:41 PM
  Please educate me on 3 speed trans RAT & RAN? Mill Knob 11 9,540 01-11-2011, 10:34 PM
Last Post: Mill Knob
  Looking for Spring Shop 2000F150SAS 5 3,529 09-24-2009, 09:52 AM
Last Post: 2000F150SAS
  C4 Trans. Cooler Fittings jrshepherd 14 7,707 09-22-2009, 05:44 PM
  Question: Trans lines and Gas tank jrshepherd 0 2,444 08-24-2009, 10:22 PM
  Question about some thing?? Mill Knob 2 2,045 03-05-2009, 02:37 PM
  Trans. Idea BigBird13 2 3,662 10-24-2008, 05:00 PM
Last Post: BigBird13
