1990 Bronco 8.8 Rear Question
Any on know if this is a 28 or 31 spline axle?
Also, can this rear be replaced with any full size 8.8 Bronco rear?
Thanks
31 spline
First instincts say yes, you can replace it with any year 8.8, but is your VSS in the 8.8 or your transfercase? Obviously, if it's in the 8.8 then you'll need another 8.8 that is equipped for a VSS. If it's in your transfercase then you're good to go with any rear end...even a 9".
VSS? Is that the extra ring gear behind the ring in the rear?
Also, what is the front rear, Dana 30, 35, etc.
Thanks
F1504x2 Wrote:VSS? Is that the extra ring gear behind the ring in the rear?
Yep, that's part of the VSS. The other is a sensor that is on top of the diff and reads the teeth of that gear as it spins.
VSS is vehicle speed sensor. In my later year model, the VSS sends electronic pulses to the speedometer, there is no "cable". The truck also uses the VSS to determine the shift points for the E4OD transmission.
F1504x2 Wrote:Also, what is the front rear, Dana 30, 35, etc.
It's a high pinion Dana 44. "Reverse cut" or whatever you want to call it.
So is the same part in my 2000 F150 8.8!
Thanks, John
Oh yes, your '00 has the VSS too.
I would the part numbers were different, but the principle of how it operates should be the same...
Thanks for the great info!!
John:beer:
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,390 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,820 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 8,695 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,310 12-12-2016, 11:54 AM
  BC Bronco Soft Top knoxville714 3 4,959 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,733 01-31-2016, 03:55 PM
  Lighted rear view mirror chuzie 6 7,482 06-20-2015, 12:18 AM
  Steering shaft Extension Question??? Broncitis 4 4,498 04-17-2015, 02:27 PM
  Another Bronco Floor Replacement jdowns67 83 31,496 12-20-2014, 11:33 AM
  rear main seal snipes243 5 4,880 05-03-2014, 11:45 AM
