my bronco build pics
#61
bought my upper 4 link mounts .
[Image: img_2024.jpg]
got my 16" coilovers. and lower mounts.
[Image: img_2037.jpg]
and a box of rockwell parts. boot guards, mohawk pans, pinion brake mounts,and some maltese cross gussets for my cage.
[Image: img_2038.jpg]
anyone buying rockwell parts needs to go here:
http://mudprometalworks.com/home
this guy is super cool and his parts are top notch. good prices as well.
and he is a bronco owner to.
Mike,
Are you using the same body and frame just switching to rockwells? The suspense is killing me.:popc1:
cuz1 Wrote:Mike,
i will be using the same body and frame . the wheel base will be stretched again from 108.5" to around 115" . im gonna run larger tires but not sure what size yet. :xyxthumbs:
It will be swaaaaaattttt!:notworthy:
WOW 115"!!!! Are you going to 4 wheel steering also?
Do you think I'll have any trouble at 102" on 40's?
SC74 Wrote:WOW 115"!!!! Are you going to 4 wheel steering also?
i have 108.5" now with 42's. remember i was running 39.5's before.i would think you should be fine at 102" on 40's . ive seen less on 40's.
im not going 4 wheel steering anytime soon. it cost a lot more. :xyxthumbs:
Sounds like you'll be busy for a little bit. Can't wait to see pic's of the on-going process!!:popc1:
Gubni Wrote:115 seems a bit long, but with 52" boggers it would be about right. Any ideal of a time frame you hope to be done?
i hope to get started pretty soon. so far i have about all the parts for the rocks so im gonna rebuild those asap. ive got to get all my link inserts and joints and tube next week hopefully.
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 5,160 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 3,128 07-12-2016, 08:04 PM
  Broncitis Rat Rod build thread. Broncitis 121 29,326 04-01-2016, 10:53 PM
  Lil Red Riding Hood Build Broncitis 11 6,767 03-04-2016, 12:14 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 2,877 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 2,513 05-19-2013, 08:43 PM
