Mystery Bronco, need your expertise to solve
My recently purchased Ford Bronco is a mystery. VIN# makes it a 1985, the engine block e9ae and makes the block a 1989, the engine side of the fire wall is stamped 1987....please take a look and give me your opinion. I want to know if this is a 302, 351, or whatever. Also knowing the body year will help when fixing or upgrading things. I do know the fiberglass top is newer, was told a tree fell on the old one and that why it has a newer paint job.....so the new top would match.
Any information will be much appreciated!
Dave
Pics are posted on link below:
http://s1346.photobucket.com/user/david_...tory/50861
I don't know the FSB all that well, but the headlights appear to be 87-88 or later. A 351w will be physically wider than a 302, but the valve covers and heads are similar. Does the VIN on the body or door post match the title? I'd guess that you have an 85 with a newer front clip and replacement 302. An 89 would be efi and serpentine. I think an 87 might be as well. Not sure on that. It doesn't appear that this truck was a later model.
The VIN does match, as a whole it is a 85 except for engine and front clip. I agree the front is an 87 or 88. Best I can determine is that the block is from an 89 (E9AE8015AA82D9)but with a 4bbl Edelbrock Carb....it is not EFI and it definitely is not serpentine, it has 3 separate belts. Thanks for confirming some of my thoughts on it.
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,527 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,942 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,077 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 5,130 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 7,003 01-31-2016, 03:55 PM
  Another Bronco Floor Replacement jdowns67 83 32,816 12-20-2014, 11:33 AM
  OK. I love my Bronco again Timstrk 3 4,458 05-19-2013, 08:43 PM
  Bronco Help Around Greenwood Jbass 29 20,183 01-20-2013, 03:16 PM
  Bronco techs in/near Raleigh? Mbowles 10 5,703 11-30-2012, 07:07 PM
Last Post: Mbowles
  Looking for Troubleshooting Tips for a 79' Bronco Rear Window (Powered). UTFLIWGYA 5 6,908 10-29-2012, 05:41 AM
Last Post: UTFLIWGYA
