time for new axles!
#31
fdezone Wrote:do you know whether converting the rear D60 from drums to discs, will cost you an inch or two in width? I'm thinking in the end you might need to run spacers on an axle to match 'em both up.
I put disc on my rear and do not think it changed the width, but I will pull a tape and compare it to the front when I get home.
SC74 Wrote:I put disc on my rear...
Did you piece meal it together or go with one of the kits that includes the brackets, calipers & rotors?
Failure is not an option!
I bought brackets off of ebay and the guy gave me a list of parts to make it work. It ended up costing a total of aprox. $250. I measured my front and rear and the rear is going to be aprox. 5" narrower than the front - I didn't expect that.
There's a 60 KP for sale in Mass on Pirate now. This is a super good deal.
http://www.pirate4x4.com/forum/showthread.php?t=634809
Not sure if this will help, AA manufacturing makes brake caliper brackets.
Might be able to use one of there univrsal weld on brackets might work.
In addition to A&A Manufacturing (http://www.aa-mfg.com/pdshop/shop/item.asp?itemid=1005), here are a couple of other sources:
Ruff Stuff has weld on disc brake brackets for $38.
[Image: weld%20on%20brake%20brackets.jpg]
Great Lake Offroad $66.
[Image: dodge.jpg]
Blue Torch Fab has some nice ones for $99.
[Image: dana60brake.jpg]
I'm going with BTF. They supposedly work with front rotors & calipers from a 73-87 GM 3/4 ton axle.
I'm going with BTF. They supposedly work with front rotors & calipers from a 73-87 GM 3/4 ton axle. I would imagine those would be readily available at most auto parts stores.
SC74 Wrote:I measured my front and rear and the rear is going to be aprox. 5" narrower than the front - I didn't expect that.
5"? What are you gonna do? I'm currently running 1.25" spacers on all 4 corners and I've run 'em in the past on other vehicles with no problems, but 2.5" wheel spacers seems a bit much. But then again, they'd only be mounted on the rear axle. Or I guess you can go with 1.25" wheel spacers out back and live with the 2" difference. Would that be more acceptable?
[Image: wheel_adapters_MAGNUM.jpg]
I'd definitely want all the wheels to have the same BS as well, so what other options does that leave, shorten the driver's side front axle tube and go with custom axle shafts? I'll research further...
fdezone Wrote:Blue Torch Fab has some nice ones for $99.
Those look exactly like the ones I got off of ebay for around $60 and used the GM parts. I can't find the ones I got, but a similar one on ebay is
http://cgi.ebay.com/ebaymotors/Ford-Dana...enameZWDVW
for Buy It Now at $70.
BTF has awesome products. I usually pay more for BTF, but their service is awesome. They've shipped me the wrong parts before, charged the wrong prices for parts, etc. - but no matter what they always make it right to me without any hassle (credit my CC, send new parts and tell me to keep old parts, etc.).
SC74 Wrote:There's a 60 KP for sale in Mass on Pirate now. This is a super good deal.
I believe this is one and the same (Westfield, MA 01085).
http://cgi.ebay.com/ebaymotors/ws/eBayIS...:IT&ih=016
[Image: cd7c_1.JPG]
[Image: c859_1.JPG]
SC74 Wrote:Those look exactly like the ones I got off of ebay for around $60 and used the GM parts. I can't find the ones I got, but a similar one on ebay is
Yeah, those are the GLO ones. Maybe I'll go with those and use the money I save towards purchasing their HD diff cover.
I'll have to call 'em though. The picture on their website (above) doesn't show the bracket going all the way around like the BTF ones. I just liked BTF's better because I figured the more coverage and bolts, the better.
SC74 Wrote:Here's a balljoint front 60 on pirate now.
http://www.pirate4x4.com/forum/showthread.php?t=633835
Damn, the asking price went down and it finally sold for $650.
  It was the first time. . . nhopman 10 3,274 03-15-2016, 12:12 AM
  Well it is time to build one from scratch... shon 4 2,764 05-25-2015, 04:28 PM
  Narrowing axles from a 77 F150 4x4 Crawdad 5 2,164 05-27-2013, 09:13 PM
  New guy, 1st time Bronc hankster 17 3,310 11-28-2010, 03:19 PM
Last Post: hankster
  Chromoly axles badbronco 4 1,432 10-06-2009, 09:30 PM
  8.8 disc brake axles Bronconrocks 0 1,500 09-30-2009, 07:50 PM
Last Post: Bronconrocks
  first time in the mud with gumby! gumby93 8 2,752 07-22-2009, 08:57 AM
  to much time berg bronco 13 3,276 06-05-2009, 09:19 AM
  dana 44 stub axles yvon 10 3,253 06-24-2008, 09:37 AM
  time to push the limits blazinchuck 51 8,642 04-11-2008, 01:45 PM
