Threads: 42
0
Edelbrock Performer RPM clone by ProComp for the intake and a Demon 650 vacuum secondary. I run a HEI conversion distributor. If you don't have at least 2" of body lift you may have clearance trouble with the distributor and the hood.
Threads: 84
0
Loving the progress. That is how most builds start, something small turns into a major build. Always remember to match your cam to what ever intake you go with.
Decide what you put into your motor on what you plan to do with your rig. I know you have been hesitant to take your ride off road since the body is so clean. That is true for the tranny too. I would only switch to a 435 if I wanted to crawl more or had such large tires that I needed it to get going. If your tranny works with the size tire you have and for the type of wheeling you want too do. Then save the money and time for engine upgrades. Some cheap upgrades you can do are the later model stock distributer with an mallery ignition box. Or pertronix and an aftermarket ignition box.
Threads: 135
0
Cool... I've had a lot of good luck with the Carquest Machine shop (believe it or not) on Germantown road (near State surplus)...
Threads: 24
0
73Bronc, I installed a Pertronix ignition in my 74's 302 last summer. One of the best and easiest mods I have ever done. Don't know why I fooled with points all these years....
![Confused Confused](https://cb4x4.com/images/smilies/confused.png)
cratchhe: :banghead:
Threads: 15
0
pertronix is tha bomb. and toss the points in the dash for a back-up. But I believe it to be one of the best 70$ you can spend.
I think my rust is rusting...
Threads: 15
0
pertronix replaces the points type ignition. not needed with the HEI style.
