Need help with transfer case install
It's hard to know for sure because everything is hidden within the section that sits between the case and the transmission. I'm thinking if I can use the long bolts as guides then at least I'll know that the entry angle is correct and then work on the spline alignment once I get it close enough. I guess it would help to have the transmission in gear when we try it tonight.
Oh, and can someone send over a babysitter to help my wife with my three kids while I continue to wrestle this thing :hysterical: :bdent:
When momma aint happy, bronco work is more stressfull Confusedupergrin:
73Bronc Wrote:Oh, and can someone send over a babysitter to help my wife with my three kids while I continue to wrestle this thing :hysterical: :bdent:
Chuzie? Can you send the Babysitter? :hysterical:
mine went together fairly easy had to use bolts to pull it the last inch or so but the rest slid right together. have to make sure you are level with tranny.
ratchet straps is how i got mine to line up
73Bronc Wrote:When momma aint happy, bronco work is more stressfull Confusedupergrin:
And drinking beer while working on the bronco while momma aint happy makes her even MORE unhappy!
true...momma says i drink more than i work lmao
Well, yet another round with no success :banghead: :banghead:
We get it about 2 inches away and need to lift the case up an inch or so to get everything level but there's a body support crossing in that spot and it prevents the case from coming up to level.
Time to take a break and come back to it. I might just move forward with the body lift, that should give us the clearance we need to level it.
All this effort, momma unhappy, no successful install... well, the beer's cold :hysterical:
what body support? Is it the rib under the tunnel?
give us some pics of the surrounding areas. are you stock body lift right now? did you put the case in gear and rotate the output shaft to ensure the splines are not an issue when mating?
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 2,705 09-19-2018, 02:50 PM
  Adjusting Transfer Case Shifter jdowns67 1 883 10-27-2014, 01:49 PM
  t-shift t-case won't go into 4-lo scbronco 3 2,508 04-01-2014, 09:54 AM
  what transfer case Ron Burgandy 4 1,956 08-18-2013, 11:06 AM
Last Post: 1st Bronco
  Southern Rods AC kit install..part 1-heater blazinchuck 22 7,603 03-09-2013, 09:47 PM
  ebay radiator(5.0 conversion) install... blazinchuck 8 5,662 10-15-2012, 10:30 PM
  Rattling/clicking noise from Transfer case jdowns67 3 1,406 05-15-2012, 08:03 AM
  bushing install ? firefighter2134 2 2,877 08-11-2011, 10:30 PM
  Oil Pressure Guage install location??? Crawdad 3 2,179 04-12-2011, 12:35 PM
  90 Transfer Case Queston 2000F150SAS 0 2,172 03-28-2011, 10:17 AM
Last Post: 2000F150SAS
