Oil Pressure Guage install location???
I bought Sun Pro guages and I was wondering where some of you all installed your oil pressure line to the engine block. The instructions were not very helpful. I have an oil pressure sending extention with the oil pressure sending unit at the end with the wire attached at the end. Simple enuff huh?? Do I need to tap the extention tube??? Any advice would be great! Thx!
Just remove the sending unit and install your pressure line. Should be simple enough. The wire and sender will not be needed with the use of the mechanical gauge.
when i done mine i opted for the copper tubing upgrade for 10 bucks. well worth it because the plastic line that comes with the guages is crap imho. but i took the factory sender off and installed the pcs from the kit into the extension.
i posted on your other thread....buy a brass tee and run both...simple
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,514 09-19-2018, 02:50 PM
  Southern Rods AC kit install..part 1-heater blazinchuck 22 12,452 03-09-2013, 09:47 PM
  ebay radiator(5.0 conversion) install... blazinchuck 8 8,040 10-15-2012, 10:30 PM
  bushing install ? firefighter2134 2 4,120 08-11-2011, 10:30 PM
  TRO install on my '77 chuzie 9 5,896 12-28-2010, 06:41 PM
  ididit install berg bronco 25 10,050 12-27-2010, 01:09 PM
Last Post: berg bronco
  Need help with transfer case install 73Bronc 34 16,959 08-18-2010, 11:45 PM
Last Post: 73Bronc
  Need Speaker Install Ideas 73Bronc 20 9,858 03-19-2010, 09:00 PM
  HELP INSTALL POWER STEERING PBONE2000 3 2,813 12-11-2009, 01:08 PM
  Mini Starter install jrshepherd 2 2,349 11-23-2009, 08:30 PM
