Project Snow Ball
#51
You can do the 2" body lift easy. The hardest part is removing the factory body mounts since they are usually rusted or seized. A sawzall cuts them well though :bdent: If you like the look of aftermarket hoods then I would do that though. Congrats on getting it installed!
ya body lifts are easy I put a 1" on mine without any trouble. the fan gaurd and bumper gaps are the only thing to worry about.
I really like the look of the hood that I have so I'm planning to go with the body lift. I was able to shut the hood without the air cleaner and I have about an inch of space. So I'm planning to pickup a low profile cleaner and then estimate the body lift that I'll need to clear it. I'm hoping 2" will work. My gut says going > 2" will require more adjustment in other spots.
Who makes the best body lift kit?
i bought mine from wild horses. i know that nix trix makes an aluminum body lift in colors. but i think the vendors are all within a few dollars of each other.
x2 widhorses is good you just have to pay for shiiping
A pretty productive night last night:
  1. New Pilot bearing - check
  2. Fly wheel - check
  3. New Clutch - check
  4. New Pressure plate - check
  5. Bell Housing - check
  6. Starter - check
[Image: IMG_9076.jpg]
Passenger side headers were a tight squeeze as you can see.
Getting closer! :toothy12: :beer:
berg bronco Wrote:ya body lifts are easy I put a 1" on mine without any trouble. the fan gaurd and bumper gaps are the only thing to worry about.
What's the method to use when jack up the body?
i used a floor jack and jack stands with some 2x4s. u wanna keep it as level as possible. small increments so you dont damage the body any
ok, so raise up both sides to an even level, not one side at a time.
  Project "Big Country" - Front Bumper Fab SC74 458 65,209 01-08-2013, 02:09 PM
  Project Mall Crawler broncosbybart 11 3,540 12-23-2011, 11:21 AM
  My 70 Sport Project..."Nothin' Fancy" ncsubronc 11 3,184 10-24-2011, 02:15 PM
