New Ride 86 Full Size
#41
What else do you need for the SAS?
jollygrngiant Wrote:What else do you need for the SAS?
A transmission with Second Gear! Confusedcratchhe:
Just a couple of brackets for the drag-link and support the engine cross-member that has to be cut. First I have to get the tranny working right, this thing is kicking my a$$. :banghead:
More updates to come. :popc1:
what is going on with the C6?
It didnt have 2nd gear from the start and after a few miles the governor got gummed up and lost 3rd gear. Pulled the governor out yesterday and filtered the fluid. It already had metal and gunk in the pan, I had flushed the cooler, but maybe the break in of the clutches caused this? Didnt take the Valve Body back apart to clean it but I am going to swap a clean one out in the next couple of days. All air checks are working when I removed the valve body, even the 2nd gear servo. Then when draining the [SIZE="4"]new[/SIZE] torque converter found out the drain plug is stripped, had to put it back in but is could be leaking, had a bunch of fluid in the bell-housing from draining it but not sure, going to have to re-tap and install a new plug also, but just screwed it back in to see if the governor fixed the shifting issues.
So how much is a CARTA bus pass anyway? :banghead:
I am so frustrated with this whole truck. If I can get it shifting good I may just sell it and get a 79 Bronco to replace it. No SAS needed on that! :xyxthumbs:
josephitguy Wrote:I am so frustrated with this whole truck. If I can get it shifting good I may just sell it and get a 79 Bronco to replace it. No SAS needed on that! :xyxthumbs:
I like the way you think!!:beer:
Cleaned up another Valve Body and put it in tonight. The trans has 2nd gear finally, shifts exactly like it should. Needs a shift kit b/c it is a little to soft for me, but WOT it goes through the gears just fine. Damn, now I have to give Eddie back his Cummins, maybe I wont tell him. Finally this thing is one the road. The turning radius between this and the crewcab is night and day. Drove around N Chuck for a couple of hours and felt like the back end was sliding around, real twitchy too, I'll get used to it! Dont really have a choice, do I?
glad to hear ya got the tranny fixed Joseph!
Thx Chuck!
Drove it to work, the Assistant Admin for the County moved the cement barrier for the Crewcab to fit into the parking space I always use. The Bronco only takes up 3/4 of the space, guess I gotta move it back!
Well now that its operating, you gonna drive it to chucks party?
Well, not planning on walking, its my only ride. Confusedcratchhe: :hysterical:
  UNF Veterans ride NC-Fordguy 2 1,032 09-26-2017, 11:08 PM
Last Post: NC-Fordguy
  Any Interest in doing a URE trail ride Saturday the 23rd or 30th? Broncitis 24 4,521 04-27-2016, 08:46 AM
  Charlotte Motor Speedway looking for a nice 1980-1996 Full Size BicksBroncs 0 1,360 09-10-2015, 05:18 PM
Last Post: BicksBroncs
  Brother In Law got a 92 Full size Broncitis 0 1,170 07-17-2015, 11:43 PM
  How to have a successful trail ride blazinchuck 9 2,405 05-11-2015, 02:13 PM
  Afternoon ride Wickedlester 1 779 05-11-2014, 01:48 AM
Last Post: Phoneman
  My new ride! broncosbybart 21 3,589 12-03-2011, 10:13 AM
Last Post: Timstrk
  tube doors for full size bronco pre-made and ready for you!!! huntingflastyle 8 6,272 09-19-2010, 05:46 PM
Last Post: huntingflastyle
  Full Size johnpaulgolf 35 7,142 08-05-2008, 06:32 PM
Last Post: DeTowman
  84 full size bronco allen227 12 4,478 01-26-2008, 10:56 AM
Last Post: DeTowman
