Homebuilt SxS
Took it over to a friends to bend up some tube.
The next day he sent me some pics from his afternoon free time.
[Image: standalone&embedded=1]
you can really see how much higher the rear is sitting in these pics.
dayum, howd i miss this?? love the tube work!!!
ParadisePWoffrD Wrote:I was planning to use a Yamaha Rhino plastic, but after removing the hood and sitting it on there, it just didnt fit well. It was about 3" too narrow on each side. After contemplating removing the whole body, I figure I would save that for later.
Instead I hope to have it look similar to this.
[Image: attachment.php?attachmentid=6236&d=1361331965]
im digging the heck outa that!!
Went over Sat & basically finished the tube work. Then we went riding.
These things are fun since you can almost take then down atv trails.
Once i add the new headlights i will finish the front tube.
Need to mount the tank solid & re-hang the sheet metal.
Also thinking bout picking up some cheap doors to make half doors with if anyone knows where some are.
there was one with doors at our locally lkq...thats been a while tho (couple months) doubt its still there. cant wait to see it finished...i bet it is fun!
How does it handle on the road? I love the work so far!
well currently it pulls to the left some... need to fix the steering. Other then that it does fine upto about 40, then the tires start to vibe a good bit.
With the 30s on it, it still has enough power in high range... when I had 34s on it, there wasnt even enough to start out in high.
I still want to put the turbo on it. But for now... finish the small stuff and wheel it some. See if the IFS can hold up. I know where a supply of sami axles is if needed, but hope i can keep her alive.
Got the cage finished for now & some lights put back on it.
Still need to fix the steering & add some storage in it.
[Image: bady6ara.jpg]
[Image: sa8uqevu.jpg]
[Image: pugygume.jpg]
Looks good, bring that thing to ure!!!
That is the plan. Hope to get it out often this season.
To much fun might lead to out going bigger
Users browsing this thread: 28 Guest(s)
