My 76 repairs.
Nicely done, Chuck! That's the kind of man he is. :biggthumpup:
Grand Poobah strikes again! Glad you got it back together and running well. If the flex plate were the wrong weight I think it would be an unbearable shake. How bad does it vibrate?
You bringing it to Charlotte?
It's has a good shake to it at low rpms and somewhat smoothes out around 2.5-3rpms. I don't have a tach installed on it so I'm just guessing. A tach is on the list.
I will not be driving it up to CharlotteSad. I'm riding shotgun in the '77 with Chuck.:xyxthumbs:
So how much did he charge you for the work he did and the labor and all?
jollygrngiant Wrote:So how much did he charge you for the work he did and the labor and all?
$30/hour...for full members cmon:beer:
find that anywhere else in town:popc1:
thanks guys! i couldnt let the man down:biggthumpup:
Imagine what it would cost for a shop to tear down the whole front of the engine, pull the radiator, replace a harmonic balancer, timing cover seal, water pump, all the gaskets(timing cover, fuel pump, water pump). and then drop the oil pan, fix/reseat the oil pump rod from the distributor, replace the oil pan gasket. Fix/replace my Shotty intaket manifold gaskets job that were leaking, and then adjust the carb and timing. Not to mention pressure wash the whole under carriage.
Just take a guess at what alll that would cost at your local service shop.
Needless to say Chuck's price was well below that!:jump:
Thanks Chuck! You are the man!:xyxthumbs:
saw you driving by yesterday as i was putting some diesel in the truck at the kangaroo on the corner of maybank and river rd. top off, cold, nasty rain and all. :notworthy:
Yep. the afternoon commute home. I haven't gotten around to installing the soft top I picked up from Crawdad. It wasn't that cold in the mid 50's, and the rain was more like a drizzel. What can I say, I love driving my Bronco rain or shine.Confusedupergrin:
DougV76EB Wrote:Yep. the afternoon commute home. I haven't gotten around to installing the soft top I picked up from Crawdad. It wasn't that cold in the mid 50's, and the rain was more like a drizzel. What can I say, I love driving my Bronco rain or shine.Confusedupergrin:
I found the installation manual for that soft top if you need it. I can mail it or pdf it to you.
Crawdad Wrote:I found the installation manual for that soft top if you need it. I can mail it or pdf it to you.
Thanks, I'll PM you.
  recent upgrades and repairs thread broncomania 50 8,445 04-24-2008, 10:04 PM
