recent upgrades and repairs thread
post up your recent repairs or upgrades on your bronco.
reinforced the backbone on my lower 4 link bars. so the rocks wont bend them.
[Image: img_1748.jpg]
added a 3rd tool box on both sides:
[Image: img_1747.jpg]
rock lights on the back. they shine all around my rear tires and they are amber so they dont blind anyone thats behind me:
[Image: img_1749.jpg]
cleaned the filters. notice the trick flow valve covers:
[Image: img_1750.jpg]
rebuilt the air shocks. ready for trail abuse:
[Image: img_1746.jpg]
Just checking out your pics, is the photo of the drive shaft at rest? It looks like you have the pinion angle direct(IE pinion at the same angle as the shaft). This can cause major pinion falure. Have you had it like this long?
broncomatt Wrote:Just checking out your pics, is the photo of the drive shaft at rest? It looks like you have the pinion angle direct(IE pinion at the same angle as the shaft). This can cause major pinion falure. Have you had it like this long?
Matt, as I understand..the drive shaft should run level or about 2degrees under. This is only true for shafts running double cardan joint shafts. the 2 running at the tranny cancel out the one at the rear end.Just my .02Confusedcratchhe:
nice job on the lower links, Shawn has the exact same thing done to his on his yota!!!
At the local meet @ godevil's 03/26/08 I had some issues with my headlights cutting off and on after awhile so I got some offroad lights mounted and put them on a toggle switch in case this happens on the road I won't get a ticket.
new lights with covers on
[Image: th_newstuff001.jpg]
one in action
[Image: th_newstuff002.jpg]
new interior lights...we were ridin in the dark alot and I could not find nothing in the cab
[Image: th_newstuff004.jpg]
my baby's home
[Image: th_newstuff005.jpg]
my work area
[Image: th_newstuff007.jpg]
my sticker catcher
[Image: th_newstuff008.jpg]
it rarely sees 20mph but its fine like it is. i can adjust it a little in the 4 link but if it aint broke , dont fix it. and its not as bad as it may look.
thanks. :biggthumpup:
I built a new set of radius arms and installed some nice new dents in the body:hysterical:
66 Rockrawler, 66 RestoMod
[SIGPIC] [/SIGPIC]
Nice. Did you and Chuck purchase your dents from the same vendor? I am looking to get some soon but have been saving up my money first.
I've been waterproofing the 78 bronco...
After the floors were repaired I primer'd them
[Image: img_7116.jpg]
After that I did some sound deadener/rubberized coating to seal/waterproof and sound deaden the vehicle:
[Image: img_7122.jpg]
[Image: img_7123.jpg]
Next I added a waterproof membrane to the floor, very thick and permanently waterproof:
[Image: img_7138.jpg]
I double layered it in strategic locations to make the water all flow out of the truck instead of pooling anywhere:
[Image: img_7129.jpg]
I'm half-way done with the back:
[Image: img_7158.jpg]
Next I will put down the vinyl floor and install neoprene seats. I plan on keeping the top off most of the time. I've got one soft top for it, looking for a different style. :beer:
(I'm into this little project at over $370 bucks. Goodness knows it beats the floors rotting out)
The Trucks
[Image: img_0041.2.jpg]
The Kompany Kool AKKountant
Nice work on the arms Travis!!
so how well does the water proofing work with the hole for a shifter:hysterical:
just kiddin, that looks really nice Audra!:xyxthumbs:
  Broncitis Rat Rod build thread. Broncitis 121 58,184 04-01-2016, 10:53 PM
  My 76 repairs. BucknEB 30 12,830 08-29-2011, 04:12 PM
  5.0 EFI upgrades? blazinchuck 4 3,113 07-25-2011, 10:57 PM
Last Post: nhopman
  Front D44 Ring/Pinion and upgrades scbronco 17 7,181 12-31-2010, 10:07 PM
  Lisa's '77 Upgrades blazinchuck 22 8,742 12-29-2010, 01:37 PM
  Stock 66 interior rebuild thread 66stocker 37 19,478 04-03-2010, 11:07 AM
Last Post: 66stocker
  miscellaneous ford tech thread... blazinchuck 0 3,723 02-17-2009, 11:02 AM
  The Roll Cage Thread johnski 4 5,657 10-30-2007, 09:50 PM
