aftermarket tilt columns? also cruise control
So it is a GM column? IDIDIT?
So I assume you are going to need a GM style control switch?
Here is a page with all the Rostra control switches.
http://www.rostra.com/aftermarket-cruise...rostra.php
Jbg is ididit..with ford style blinker and a GM wheel.
Duff is flaming river with bolt in blinker...in sure on wheel mount.
new ididit column on the way from jeff's...mild steel, so it has to be painted. still gotta order cruise system
Hey did you see the one that speedway has? It is under $300.
i did and even found one from southern rods cheaper...but i didnt want to fab up anything or take a wrong measurement...the one from jbg should be a drop in. all the others also came with some type of a double D output shaft which required a $70 u joint. jbg's is splinned like the ford.
oh I didnt notice you had already ordered!
Hoping it shows up today! Gotta paint it and wire in the cruise control knob
got the new column...looks nice. i was a little aggravated. i called 3 time over a week and a half to confirm all the issues with ididit and which turn lever was needed(ie. GM -bolt in, ford-screw in) they assured me screw in...well, just to be sure i wanted to wait to order the cruise control and switch lever. sure enough, it showed up and was a GM bolt in! right on...id be screwed if i took them for their word and ordered the ford screw in. anyway, got cruise ordered and called jeff's...they refunded me the difference between the ford and GM style...so they gave me back $20 on my card. im happy with that. they need to understand what they sell.
got the column painted black last night and loosely ran one wire down threw the column...i will use this to pull the cruise harness down threw column later.
Nice shaft!!!!
So is that plug style compatible with your centech / painless?
  Idlew Air Control Valve 1996 5.8L jrshepherd 2 1,445 06-11-2012, 02:17 PM
Last Post: jrshepherd
  cruise control?? blazinchuck 13 2,217 10-31-2011, 09:46 PM
Last Post: NicksTrix
  tilt column berg bronco 8 1,295 12-13-2010, 07:37 PM
Last Post: berg bronco
  the smog control supertoyota88 6 1,294 05-06-2009, 02:24 AM
