Idlew Air Control Valve 1996 5.8L
Confusedcratchhe::banghead:Hello. I know someone knows more than me and can help. I had the engine rebuilt on my 1996 5.8l. I installed forged pistons, cam, roller rockers, trick flow heads, full length headers, 26lb injectors, new air meter, arp head studs and a load of other new parts. I have had a lot of issues with vacum leaks/ lean codes (p0171 & P0174). On the other hand, I have had to replace the IACV twice. after 500 miles +/- it will stick around 2000 rmp and not let the idle drop. When I disconnect the IACV it runs great with readjustment to the idle. Any suggestions? Thanks
Why is it failing? Is it getting contaminated with carbon?
The timing was off and prevented it from work. Once the timing was adjusted everything works great. Thansk again.
  Charlotte Motor Speedway looking for a nice 1980-1996 Full Size BicksBroncs 0 2,106 09-10-2015, 05:18 PM
Last Post: BicksBroncs
  aftermarket tilt columns? also cruise control blazinchuck 19 6,452 03-06-2013, 07:41 PM
  1996 Bronco w/egr Headers 5.8l jrshepherd 2 2,477 06-30-2012, 10:31 PM
Last Post: DirtyWhiteBoy
  cruise control?? blazinchuck 13 5,445 10-31-2011, 09:46 PM
Last Post: NicksTrix
  1996 Lifts jrshepherd 5 3,262 05-05-2011, 01:56 AM
  mass air? bone collector 2 2,733 05-30-2010, 07:37 PM
Last Post: lobo1117
  the smog control supertoyota88 6 3,092 05-06-2009, 02:24 AM
Last Post: supertoyota88
  Air Cleaner help redsblue73 12 6,313 01-06-2009, 12:49 AM
Last Post: redsblue73
  Air conditoning issues tapiot 6 3,504 09-15-2008, 05:19 PM
