08-18-2011, 03:08 PM
Just curious as to whether anybody out there can answer a question about the disc brake conversion. Will the disc brakes off of a TTB dana 44 fit on a solid dana 44?
Disc brakes
08-18-2011, 03:34 PM
Never tried that but I dont think so. I'm guessing your using a drum brake solid axle out of an eb, which would have a 6bolt pattern to the spindle. The only disk brake swap for that knuckle would be from a chevy or a scout(which uses the chevy parts).
08-19-2011, 01:34 PM
Or you can do the Ford conversion which uses everything from the knuckles out from a 76-79 150 4x4 or 78-79 Bronco. That's what I did.
08-19-2011, 10:53 PM
dixieboyz13 Wrote:Just curious as to whether anybody out there can answer a question about the disc brake conversion. Will the disc brakes off of a TTB dana 44 fit on a solid dana 44? the ttb stuff uses a 6 lug pattern like an EB does. if my memory serves right (which it usually doesn't), you can actually make it all work. i vaguely remember using a spindle from an EB on a FSB. i think you will have to use the TTB outer axle shafts though. not too hard to do. |
Late 70s Cadi rear disc brakes for 77 banjo rear end | Crawdad | 11 | 3,631 |
01-11-2014, 12:26 AM Last Post: Crawdad |
Brakes!!!! help needed!!!!!!!!!! | Brushmaster | 9 | 4,817 |
09-06-2012, 03:18 PM Last Post: blazinchuck |
Brakes bled and pedal goes to the floor but I do stop... sort of. | chuzie | 70 | 10,289 |
02-07-2011, 10:20 PM Last Post: scbronco |
Early Bronco Brakes? | Errorhead | 7 | 2,771 |
09-18-2010, 10:18 AM Last Post: chuzie |
cutting brakes | snipes243 | 2 | 1,735 |
02-15-2009, 09:41 AM Last Post: Timstrk |
Rear disc | cuz1 | 5 | 1,313 |
07-25-2008, 01:23 PM Last Post: bucketobolts |
disc brake cut away | cuz1 | 5 | 1,328 |
05-21-2008, 07:22 PM Last Post: broncomania |
rear disc brakes***HELP*** | blazinchuck | 24 | 5,005 |
12-30-2007, 03:15 PM Last Post: jollygrngiant |
