Rear disc
I took the rear disc brake set up off an old Ford LTD 9". How do I put it on my early bronco? I assume the LTD had a large bearing set up and would need to change my current bearing set up. Help me!!Confusedcratchhe:
carl w
You still have the original housing in your rig? What year is it?
Carl - Does the LTD have a 5x4.5 or 5x5.5 bolt pattern?
yes, I have the original (small bearing) housing. I do think the LTD is a 5 on 4.5
I did not think of that before I got the set upConfusedcratchhe:
Carl, I had that setup on mine for a while before I switched to the kit I built.
There are some flaws with those kits.
1 they have a smaller lug patern than the trucks. So you will have to redrill the lug holes in the rotor.
2 you will need a big bearing housing to make it work.
3 You will need larger lug studs(like the orginal lincon had).
Those calipers are expensive, but you can swap normal front calipers if you dont want the ebrake setup. I was never a fan of them, mostly due to the h pin (like the stock fronts) they tend to stick and burn the inner pad.
If there free, it would be worth trying to find a big bearing housing.
I have a write up at home (coppied from the web years ago) I can post if your interested.
That should be the early BB housing on the caliper brackets. They should fit a full size or F150 rear. There is also "Torino" big bearing that floats around out there.
I used the brackets, rotors, and calipers from a '92 Grand Marquis on my small bearing rear under my rig. Took a little fab work but not too bad.
Have you thought about weld on brackets for a dirt track car? I believe you can use either a '80's F150 or CJ7 front rotor with them and S10 calipers. You may have $100 in the entire swap with out an emergency brake. But if you need an E brake you can use Eldorado calipers at $100 a side. But if sheap and easy is what you want: http://www.speedwaymotors.com/p/3348,15_...20brackets
[Image: 916-41008_R.jpg]
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,161 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,568 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,786 06-20-2015, 12:18 AM
  rear main seal snipes243 5 5,080 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,905 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,686 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,192 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 7,955 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,867 12-22-2012, 05:34 PM
  5.0 rear main bearing... is it going out??? chuzie 16 8,426 12-18-2012, 04:52 PM
