ParadisePWoffrd's EB
#51
you've come a long way with that thing! you gonna try and come out to URE for our Nov run? i'd love to see it in action.
thanks for the comments guys...
I will try to make it to URE... not sure what Nov has in store for me yet... also depends if I can get the 60 in or if the 44 survives a few rides in October...
went out and found I had no brakes thanks to the hose between master and distribution block...
Took the chance to upgrade to rear discs with adjustable proportioning valve...
For future reference I used:
- 91 Sidekick rotors (dont have to turn down shaft)
- GM Metric Caliper
- weld on caliper bracket... could have used bolt on instead...
If anyone knows of a good bolt-in manual master to upgrade to, Im interested...
i ran manual disc using the f250 MC bigger bore/stroke...however, since your 4 wheel disc..you'll probably need. equal size front and rear reservoir . i think a corvette MC might work...dont know yrs tho
got to wheel a little this weekend. It did the few things I asked it to do, and being slick kept the front end together...
I realized 2 things in the short while:
- Need to install an electric fan (and repair my alum rad)
- Need a bigger master for quicker brakes
Saturday I installed a new radiator and elec fan... Had to do a little clearencing to the core support to mount it as a pusher (it wouldnt clear as a puller)
I really need to get some tube work done on the front end to clean all this up..
Tonight i installed the best upgrade yet.... yup, some tunes...
got the new radiator and electric fan installed, along with a new core support... have to rework the front clip and winch mount too now to compensate...
ill get some pics up later
good dal, cant wait to see the new install pics!! tunes are always good to have lol
Here are some pics of it.
New radiator mount & brackets holding up front clip. The electric fan is under the tube as it wouldn't fit as a puller.
The h4 headlights hit the tube so I replaced them w/ some old hellas I had around. Also you can see how its farther forward now. So either need new winch mount or cut out grill.
You can really see that's its farther here. Got a few choices: stretch fender or make new mounts. Where its at now shaves ~3" off per side.
Heres the pics of the tunes. I put 12v charger with miniplug input & volume control. Also you can see the cold start plunger & rocker for the fan.
Users browsing this thread: 21 Guest(s)
