306 EFI build
#51
SC74 Wrote:You will have to trim for the TFI - or at least I did.
Also, when you set the motor in be careful of that bottom outside pulley on the pass. side. It is just a hair from hitting the cross-member.
yep, i read about both of those issues. dont wanna grind anything til i have the distributor in hand. as for the lower pulley, i hope ill be ok...im running monster motor mounts(they should be taller than stock)
Go with the explorer clutch fan and fab a good shroud. No sense in getting stranded with a part you cant replace or being forced to make an emergency replacement with something expensive you dont really want anyway.
how well does it cool yours? mine it a lil different tho...i think you have the plastic right? i have a stock shroud, that should work ok??
i dont think anyone cares on classic...seems that thread isnt getting any love
im wondering alos...if the fuel lines are gonna interfere with the new 4G alt
I have the explorer plastic fan also. I think some were metal though. Either way they move a TON of air. I agree with Chuzie!
Stock shroud will work - that's what I'm running too.
I am also running monster motor mounts and mine does not rub, but it is very close. The reason I mentioned that mainly is so that when you drop the motor in be especially careful not to let it bind there when you are getting it lined up. Too much weight on it may break the aluminum bracket. It's that close.
will do! thanks for the heads up
what fuel lines are you running? explorer lines will work fine with the intake and front dress. if you are running mutang lines, i can't say. i really like the way the explorer rails route.
the explorer fan pulls a ton of air. my griffin rad is only 22x24 (smaller than a stock EB rad). never come close to overheating, even at the 100 degree spartanburg race. i'm not running a shroud either, never got around to fabbing one up... the fan sits about 2" away from the rad. works great!
ok, well...got up today to run a few errands and had a vibration round 30-35mph. just what i thought! a dang u-joint. so, i had to fix that before starting on the motor again.
installed the new injectors and t-bird fuel rail...everything looks good so far. doesnt look like there will be any interference with the pressure side fuel line and the alternator.
i slipped the distributor in place to see how much of the bracket needs to be clearanced. how have you guys had to remove??
also, one other problem i found. when i got this gt40 intake(it didnt come with any bolts) so i pulled some bolts the last time i was lkq. the bolts came from a 97 explorer(so you would think they were perfect) however, i found the bolts are tightening down before the intake is??? its not by much, and i threw a washer under the head of the bolt, but the name plate wont bolt up right because the bolt heads sit up just a hair.%)
here are a few pics
I think the way my TFI is clocked with timing is so that I only had to cut the triangle support out - not near as much as you have marked. Motor is looking great! Nice and clean.
so just clock the distr...around another tooth or so, then the tfi plug is clear and reroute the plug wires? thanks
  Berg Build - New Guy here tcb3078 27 6,288 11-13-2018, 06:45 AM
Last Post: NicholasMo
  Tweaking Chucks most excellent build NC-Fordguy 11 3,292 02-26-2017, 01:54 PM
  Well it is time to build one from scratch... shon 4 2,524 05-25-2015, 04:28 PM
  Build threads rtj731 4 1,801 06-11-2014, 11:28 PM
  Mini build up / fix'em up jollygrngiant 30 6,089 06-04-2013, 12:22 PM
  Bronco build questions AReed 12 2,924 03-23-2011, 04:12 PM
Last Post: AReed
  efi berg bronco 5 1,153 09-07-2010, 08:01 AM
  Fall build abunchofidiots 5 2,024 10-01-2009, 10:29 AM
Last Post: abunchofidiots
  5.0 EFI/435 blazinchuck 13 2,368 09-26-2009, 06:11 PM
  Build sheets cdeal28078 17 4,130 11-08-2007, 01:22 PM
Last Post: Roughshod
