URE Fall Run 2012?
broncosbybart Wrote:that info is not correct. do you have a 351W in it? i can't remember. if you do, the early 302 (28 oz) flywheel will work. all 351's are 28oz. The only engines that are 50 oz are the 80's and up 5.0's. sounds like you will be fine.
i've heard good and bad about the BC exhaust. i had a local exhaust shop fab up my 2 into 1 on the racer. They charged about the same price and it is tucked nicely out of the way. I think a normal price on doing some work like that would be $500 though, unless you can find a deal w/someone reputable.
yeah, i found that too... i just need to verify that the flywheel thats in it right now is a 28oz flywheel... i dont know what it is... and i think i gotta take it out to verify... sux... unless someone has a trick...
My Build Thread-
no tricks that i know of, but if it came off of the stock 302, it'd be 28 oz.
It did nto come from my 302, it came from whatever JPG had in his bronco with the NP435 i got from the part out... ????
My Build Thread-
scbronco Wrote:It did nto come from my 302, it came from whatever JPG had in his bronco with the NP435 i got from the part out... ????
i remember JP claiming his motor was a roller 302, however the guy that bought it said it was not! so it should be a 28oz...hope that helps
blazinchuck Wrote:i remember JP claiming his motor was a roller 302, however the guy that bought it said it was not! so it should be a 28oz...hope that helps
Hmmm??? think i should jsut leave it together, and hope for the best? I'd kinda like to know for sure, but it soundslike odds are its a 28oz... is there a specific way to clock it on the crankshaft when installing, cuz if so i know i ddint do that, and would need to take it apart anyway... I know im starting to sound like a real amatuer, but this is no kidding the first motor/tranny conversion i've ever done... prolly stuff i shoulda thought about before i put it together, but i guess i got in hurry with it...
My Build Thread-
If you have a reduction starter just check out the casting number above it on the block. If you have a stock starter remove it and check the casting. Easy peasy pumpkin squeezy.
You can only put the flywheel on one way, so that should be correct. The bolt holes aren't symmetrical. I'd go with it.
Army proof!
im pretty sure jpg 5.0 was the newer 50 oz engine, pretty much if it has a one peice rear main seal then its the 50 oz from what ive seen just throwin
this out there.
GOODOLEBOY84 Wrote:im pretty sure jpg 5.0 was the newer 50 oz engine, pretty much if it has a one peice rear main seal then its the 50 oz from what ive seen just throwin
this out there.
and in looms the shadow of doubt...
Screw it, im just gonna take it apart... in July... hopefully i will have this done before the wrenchfest in august... if not then we will just abandon all work that involves fabrication, and get the bolt-ons done...
Thanks for the info, good bad or indifferent it helps make the decision... and gives some insight on how to be sure i get it right the second time...
My Build Thread-
  Any Interest in doing a URE trail ride Saturday the 23rd or 30th? Broncitis 24 5,358 04-27-2016, 08:46 AM
  36 Hours of URE broncosbybart 54 9,135 09-05-2015, 11:35 AM
  URE volunteer roster info needed (member names) ASAP! broncosbybart 7 1,883 06-03-2015, 06:39 PM
Last Post: rtj731
  State of the Union at URE broncosbybart 2 1,597 12-19-2014, 11:33 PM
  NOVRUN@URE 2013 pics jac77 8 2,493 11-08-2013, 09:14 AM
  6th Annual November Run - Photo Pucket Link UTFLIWGYA 1 1,651 11-13-2011, 11:00 PM
  It does run snipes243 5 1,931 10-18-2011, 10:03 PM
  Fall build abunchofidiots 5 2,281 10-01-2009, 10:29 AM
Last Post: abunchofidiots
  what exhaust and pipes should I run brewie212 4 1,538 05-04-2009, 02:32 PM
Last Post: trkbilder
  Finally washed the URE mud off my Bronco chuzie 4 1,400 04-13-2009, 01:00 AM
